12-23-2015, 08:32 PM | #1 |
Active Member
What is the best tire gauge...
Need a recommendation for a good, accurate tire gauge.
I have over the years, bought umpteen different styles of tire gauges. From professional ones used on big trucks to small auto parts store ones slider style and round gauge style. At this time I have one in each of my vehicles (4) and couple of more for my tractor out in the country. Not two register exactly the same. They all differ from one to two or more psi difference.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-23-2015, 08:50 PM | #2 |
Re: What is the best tire gauge...
I had 3 slider gauges and a round needle style gauge that all read different. I bought a digital one from an auto parts store that said its guaranteed to be + or - 0.5 psi or a certain percentage, whichever is greater. Turns out the digital and round needle type read exactly the same. I'm good with using either of those now.
Posted via Mobile Device |
12-23-2015, 08:54 PM | #3 |
I buy these in my shop, they are accurate. I also have the analog version for personal use.
http://www.tooltopia.com/astro-pneumatic-3018.aspx
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-23-2015, 09:04 PM | #4 | ||
Active Member
I don't mind if they read the same all the time, but some of the slider types tend to stick and I'm really not sure if I'm putting in equal psi on the tires. Quote:
12-23-2015, 09:22 PM | #5 |
The Niner
http://www.summitracing.com/parts/at...iews=ThreeStar
Cheap and works well. http://www.summitracing.com/parts/atm-2164/overview/ This one goes to 100 psi
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
12-23-2015, 11:07 PM | #6 |
Active Member
Those from summit are little more in my price range and one had some good reviews. Probably pick up two -one for the home and another for the farm.
I'm staying away from the $2-$3 ones at the local auto stores. They're just not accurate enough. Appreciate the response.
12-23-2015, 11:44 PM | #7 |
If you want accuracy,check out the gauges by Longacres Racing Products. With tire pressure being so critical, that's what a lot of racers use at the track.
12-24-2015, 10:17 AM | #8 |
First an answer. http://www.getagauge.com/
Second. The tolerance of a slide type gauge is very poor, but cheap. And generally good enough. A digital industrial gauge will usually give you the best accuracy. My company could sell you a 60psig digital gauge with a certified calibration traceable to NIST. Got $500? Me neither. A needle type gauge (bourdon tube) are accurate but will still vary from gauge to gauge unless you paid a lot of money for a high precision, mirrored gauge with zeroing capability. If you really want to be accurate, use the same gauge on everything and everything will have the same pressure offset (correction factor).
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
12-24-2015, 01:53 PM | #9 |
accurate tire pressure is wayyyy overrated to spend more than $10 for one is very foolish// use the simple one one all four tires and have equal pressure and if you want to raide o9r lower it to your driving style
save thew extra money for beer and tell a fib how accurate you r
12-24-2015, 03:23 PM | #10 | |
Active Member
Looks like I've been sent to the Tools, shop and safety site. Six total viewing at this time. Reason I posted it in the 67-72 message board to begin with is that I wanted a varied opinion from the large group on an important part of driving to get maximum mpg. Well, so be it. Guess I'll have to trial and error it with the few responses I got.
12-24-2015, 04:46 PM | #11 | |
The Niner
12-25-2015, 06:52 AM | #12 |
It gkt moved to tbe appropriate forum. As to tire gauges i use milton tire gauges at work they are pretty accurate.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-25-2015, 11:09 AM | #13 |
X2 on Milton. Many of their products are still made in the USA.
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
12-25-2015, 10:02 PM | #14 |
I use 100 PSI process gauges that I get from work and plumb them up on a short whip with an air hose fitting and a chuck. About as good as it gets.
12-26-2015, 06:49 AM | #15 |
I got mine from a snap on truck in the 80s
Dang thing still works, guess it was worth paying too much for
Happy as a pig in mud |
