Old 12-24-2015, 11:59 AM   #1
62 bigwindow
62 bigwindow's Avatar
Cummins swap into 65 C10??
Have been looking through pages and pages and haven't located any info or pics of anyone who has done the swap
I feel sure several have installed the 5.9 into a 60 model truck and was looking for advice or feedback before I commit to it myself.. thanks guys
62 bigwindow is offline   Reply With Quote
Old 12-24-2015, 12:06 PM   #2
Mathew21
Mathew21's Avatar
Re: Cummins swap into 65 C10??
Try in the diesel sub forum. Good luck http://67-72chevytrucks.com/vboard/f...play.php?f=240
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 12-24-2015, 12:24 PM   #3
BigSix
Currently buttoning up a 4 cylinder swap.
BigSix is offline   Reply With Quote
Old 12-25-2015, 12:33 AM   #4
Captainfab
60-66 Nut
I believe the 6BT will require some serious firewall modification. There are a thread here somewhere where a member is installing a 6BT into his C30 panel.
Old 12-25-2015, 12:52 AM   #5
spacedebris
That would be me Here is a link to my thread. Unfortunately I'm out of work so project is on hold but it should give a small idea whats involved.
http://67-72chevytrucks.com/vboard/s...d.php?t=523009
The 6bt is a tough fit. It does require a lot of firewall modification. Plus IMO the 6bt is too heavy for a stock C10. I feel that 1 ton (C30) suspension is almost a must for the 6bt.
However a 4bt should fit nicely and work well with a C10. From what I understand the 4bt does not need any firewall modification. Just my .02 cents worth.
Also here is a link to another thread asking the same question for his 62
http://67-72chevytrucks.com/vboard/s...d.php?t=687424
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue.
spacedebris is offline   Reply With Quote
