12-30-2015, 10:54 AM | #1 |
Installing two tone cab trim???
Hello, need some assistance on how to install the trim on the back of my 72 C10 cab. Do I install the clips onto the truck first or do I install the clips onto the trim piece and then install onto truck?
Any help is greatly appreciated! |
12-30-2015, 12:50 PM | #2 |
tcoop68
Re: Installing two tone cab trim???
If your talking about the trim below the rear window you install the little plastic clips on the little nail heads then the trim snaps into that its not hard. just make sure you use good clips.
12-30-2015, 11:38 PM | #3 |
If your truck didn't have the nubs sticking out to put the clips on, you can put the clips on with screws then place the trim on the body. [Clips go on body first]
12-30-2015, 11:53 PM | #4 |
tcoop68
I've got a stud gun from Mac tools that will also put the studs on just like original used it many times works great
01-06-2016, 09:35 AM | #5 |
yes exactly, with the paint divider you put clips then trim
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 |
01-14-2016, 01:20 PM | #6 |
I would recommend that you put the clips on the body first and then install the trim piece. I just had to do this with my truck to replace the fender flares.
01-07-2017, 09:26 PM | #7 |
Anybody have a link to the weld-on studs and the correct screws?
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-08-2017, 07:33 PM | #8 |
Found an answer.
