Old 01-06-2016, 04:30 PM   #1
1963ChevyC10
1963ChevyC10's Avatar
63 Big Block transmission question
Well as the title says, I'm currently building a 63 short fleetside with a 496 to drop in. Pretty much just a driver, maybe some light work. Never really worked with cars before and none of my family has either, just kinda learning as I go. Anyway, as the title says I have no clue to go with the transmission. My main goal is if possible I would love to keep the 3 on the tree. Absolutely love that aspect of the truck. I know nothing about transmissions so any advice or suggestion is welcome! Headed out to work soon but hopefully getting some pics of truck up later tonight.
1963ChevyC10 is offline   Reply With Quote
Old 01-06-2016, 05:21 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 63 Big Block transmission question
A 496 BB would shred a 3 speed trans. you could put in a 5 speed but would need to go to a floor shifter. You also put in a built 700R4 for overdrive which will cost a good amount of cash or go with a TH400 automatic. I have a stock 454 out of an 89 Suburban with a built up 700R4. I just cruise it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-06-2016, 05:24 PM   #3
MikeN
MikeN's Avatar
You could use the larger, much heavier duty 3-speed manual transmission from a 66 or newer truck, but they are difficult to mate to your column shifter, and a good quality Hurst floor shifter will be a lot of $$$. The best compromise for keeping cost down is probably a 3-speed automatic, preferably a TH400, although a TH350 is pretty stout too.
MikeN is offline   Reply With Quote
Old 01-07-2016, 01:43 AM   #4
Captainfab
60-66 Nut
I have no idea how your 496 is built but just assuming it is going to likely put out close to 500 ftlbs, I doubt that 3 speed will last very long. Of course that is subjective to what you will be running for rear tires. If you are just running some skinny street tires that will just go up in smoke, that will be easier on the drivetrain than a set of wide/sticky drag radials.
With that said, for a manual trans, a SM 420 or SM465 should hold up, but won't be any fun shifting. A TKO600 5 speed should hold up and be fun to shift but at a price. For an auto trans a well built TH400 will do the job as well as a 4L80E. Of course the 4L80E will need a controller which adds to the cost.
Old 01-07-2016, 02:31 AM   #5
padresag
3 speeds can sometimes fool you. I can remember back in the early mid 60's there use to be 2 dodges which ran at Mission Raceways. one was a ramcharged hemi(4 speed0 putting out over 5000 hp. The other was a ram charged wedge with a 3 speed. it was always a good battle. never seemed to have any problem at the races with it.
I ran a 3 speed chevy OD behind a well built 371 olds in my 32 chev and never had any problem. prior to that with the old top shift 3 speed (circa 1937) behind a 261 all that I ever did was knock 2nd synros sng you would just take it apart and put it back in and peen it and away you go. things were much simpler then and no internet to confuse ones self. it was just cars
ron
padresag is offline   Reply With Quote
Old 01-07-2016, 06:24 AM   #6
1strong63
1strong63's Avatar
use an auto like a 400 and shift it using the column shifter, i've seen a guy in a f... do that in england, with a dedicated kit. i guess it's possible on our chevy.
i have a SM465 with my mild build 482 and as captain said it's not very funny to handle.
1strong63 is offline   Reply With Quote
Old 01-07-2016, 07:51 AM   #7
PGSigns
PGSigns's Avatar
Also what is behind the trans has to be looked at. If it has the light duty drive shaft and a single track rear that will be an issue. Then you are going to want to upgrade the brakes. With the weight on the nose the drums wont cut it. The big block is not just a drop in and bolt up either. Mounts will need to be made. With you being new to mechanical work, I would start this project with the engine that is in it. Do brake and suspension upgrades first to make it a safe driver. Sort out any electrical issues next. Then go from there after you have driven it some. I went to a stout 396 in my 64 and the first thing that broke was the turbo 350, then snapped a u joint, then knocked a tooth off the rear gear. Thats when the frame rails got moved, leaf springs and a 9" ford went in it. With the big tires under it it was still not much fun to drive in the rain. The weight split just sucked. All my trucks have been small block since.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-07-2016, 11:22 AM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
We got a TH400 behind the 496 in me an dad's 77 C20. Tranny has held up fine through it all.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-07-2016, 08:36 PM   #9
1963ChevyC10
Well, not really the answer I was hoping for but thanks guys! I had been looking at a th400 before this and thats definitely the direction I think I'm going to look now.
Anyway I promised I would post some pics of the truck. Not super current as I'm hoping to put the cab back on tonight with the new floor pans installed, but it can give you a good idea of where I'm at.
Addressing some concern I do have disc brakes all the way around and I have beefed up the front suspension a bit with some more work still to come.
http://imgur.com/a/AarVj
Apologize for posting on imgur, I was having some trouble uploading. Couldn't resist posting the first pic with the truck as well. Almost 4 years ago now.
Old 01-08-2016, 11:37 AM   #10
MikeN
MikeN's Avatar
Neat looking truck!
1963, big block, transmission
