Old 01-06-2016, 10:57 PM   #1
gpgofast
Project C10/K20 Transplant
My dad's old "parts truck". He cannibalized the rearend about 30 years ago but otherwise this C10 is complete. Will be mating the body to a K20 chassis. I will probably leave the running gear stock at this time unless I can find a wrecked late 1990's Suburban/K2500. Paint is all original, in great shape other than being faded and virtually NO rust anywhere. About 67,000 miles on the A/C equipped body. It's been sitting in the Nevada desert for about 35 years. Can't wait to start.
Missing a few parts such as brake/clutch pedals, brake booster, etc..I will keep everyone updated as I move forward.
gpgofast is offline   Reply With Quote
Old 01-07-2016, 01:03 AM   #2
El Dorado Jim
Re: Project C10/K20 Transplant
will be looking forward to your progress
El Dorado Jim is offline   Reply With Quote
Old 01-09-2016, 05:45 PM   #3
gpgofast
Picked up a titled chassis in Yakima...I wish it already had 3/4 ton axles. We will see once I get the differential covers off. Clean and straight...
Old 01-10-2016, 10:22 AM   #4
gpgofast
Linked to photobucket.
Old 01-17-2016, 09:03 PM   #5
gpgofast
Frame almost ready to head to the sandblaster. All brake and fuel lines removed. Just need to wank the motor and its off. I will probably leave the axles on with the shackles broken loose to make it easier to haul. I will pull the last eight bolts at the blaster...may have to wait until we get a break in the weather...Going to be hard to paint when it's snowy and cold outside.
Good chance I will be replacing the rear axle with a 14 bolt and replace the Dana 44 hubs with 8 lug units.
[IMG][/IMG]
Old 01-18-2016, 04:23 PM   #6
El Dorado Jim
good choice on a new rear end, the 14 bolt out of a 73 or newer truck will fit, you just have to move the spring perches and shock mounts, a 3/4 ton dana 44 front end out of a 73-76 will bolt right in,, ,,,,,,,. I think the ones out of a 71-72 would be pretty hard to find, and I think most of the 3/4 ton rear ends from the early 70's were Eaton, stay away from those....stay away from drum brake front ends on '70 and older trucks..if you change to 3/4 ton axles, you will need the larger brake booster/master cylinder setup from a 71-72 3/4 ton 2 or 4 wheel drive truck,get brackets and firewall brace and rod from brake pedal to booster from a donor truck also has the proportioning valve at the master cylinder....don't try and use your 1/2 ton stuff, won't work!!!!!I have done two of these conversions......keep us updated!
Old 01-18-2016, 04:44 PM   #7
gpgofast
Jim,
Thanks for the advice. I found a front end locally with 8 lug hubs. My brother thinks he has a couple of donor 14 bolts "laying around". Sometimes nice to have excess junk around. I will be on the lookout for the correct brake master and proportioning valve.
Old 01-28-2016, 10:02 AM   #8
gpgofast
Well, I've "located" drivetrain and need to make a decision on engine. My brother happens to be some kind of "prepper". I wasn't looking to go the EFI route but when someone has a complete engine it makes the decisions for you:
Old 01-28-2016, 10:05 AM   #9
gpgofast
Also, I've located a Dana 60 out of a Longhorn and my brother suddenly "remembered" that he had an 8-lug Dana 44 with a bad ring gear.
Old 01-28-2016, 10:11 AM   #10
gpgofast
Old 02-29-2016, 09:50 AM   #11
gpgofast
Due to the weather this winter I haven't been able to blast the frame yet, but here are some updated pictures. The SM465 and NP 205 cleaned up and ready to go back in.
Old 02-29-2016, 09:52 AM   #12
gpgofast
Started prepping the body. Front clip removed and bed is ready to pull off. Once the new frame is complete, I will roll out the C10 chassis and roll under the new K20 chassis.
Old 02-29-2016, 09:54 AM   #13
gpgofast
My big brother polished a test spot on the front end!
The hood will have to be clayed to remove the tree sap, but the paint looks like it is going to polish ok!!!
Old 02-29-2016, 09:56 AM   #14
gpgofast
Interior cleaning up ok.
Old 04-04-2016, 09:13 AM   #15
gpgofast
SM465 and NP205 inspected, cleaned up and ready to run...
Old 04-04-2016, 09:18 AM   #16
gpgofast
Cab separated from the C10 frame and ready to by cribbed up to roll the old frame out.
Not sure if I stated this earlier. I am working on this truck "remotely". I live in Washington state where I am working on the chassis and the donor truck is in Nevada. I am working on the donor about one weekend a month. Once I get the chassis complete, I will haul it to Nevada to marry the two...
Makes it a little slow going, but hopefully have a driver before the fall...
Old 04-30-2016, 11:14 AM   #17
gpgofast
Frame blasted and ready for paint.
Old 04-30-2016, 08:06 PM   #18
gpgofast
Primered...
Old 04-30-2016, 08:09 PM   #19
gpgofast
Poorman's rotisserie...
Old 04-30-2016, 08:11 PM   #20
gpgofast
Old 05-22-2016, 09:49 PM   #21
gpgofast
On the way from Washington to Nevada to join the chassis to the body...
Notice the Dana 60 axle not installed yet. Didn't have eight lug rims in Washington. Will install the axle once it's mated to the cab.
Old 05-22-2016, 09:51 PM   #22
gpgofast
Cab cribbed high enough to clear the frame and rear tires...about 32 inches off the ground to the beam carrying the cab...
Old 05-22-2016, 09:52 PM   #23
gpgofast
Now have to lower the cab down. Amazing what you can do will cribbing and a hydraulic jack....
Old 05-22-2016, 09:56 PM   #24
gpgofast
Cab's all the way down. Needed to lower the rear of the frame to the ground to get the timbers out....
Time for the Dana 60 to go under...
Old 05-22-2016, 09:57 PM   #25
gpgofast
Chassis and the cab mated together...
