01-07-2016, 03:31 AM | #1 |
72 C30 (Motorhome) question, broke down on the road...
Broke down, ya think 1972 Chevy C30 MH, 402BB, 4 speed manual, 42,000 original miles.
I'm out on a buy and drive adventure with my newly acquired rig. 300 miles into a 700 mile trip the clutch pedal has gone limp ( depress it and it stays on the floor) in Clovis NM. I got it going to a hotel by turning it off at stop light and starting it in gear, quite fun It's midnight and 30 degrees outside so I didn't do any crawling around. I figured I'd ask y'all your thoughts so when I go out in the morning I will have a few ideas to check out. Is there a clutch master (slave) cylinder? Thanks for the rescue Last edited by 57NAPCO; 01-07-2016 at 03:44 AM. |
01-07-2016, 07:24 AM | #2 |
Re: 72 C30 (Motorhome) question, broke down on the road...
Sounds like the clutch rod linkage came apart . anything else seems like you would have noticed a change before it would just go to the floor .
You can use the LMC truck catalog to see a picture of the linkage set up . Last edited by Grumpy old man; 01-07-2016 at 08:09 AM. |
01-07-2016, 07:33 AM | #3 |
X2, either a cotter key fell out, or the rod fell out of the fork from having no spring to keep tension on it, or less reason, a rod broke..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
01-07-2016, 07:50 AM | #4 |
x3 and also could be a clip holding the throwout bearing fork to bellhousing , unless someone changed the clutch system it should all be mech linkage no hydraulics
01-07-2016, 08:43 AM | #5 |
I had a clutch pivot ball break off years ago on a '72 C-10. Maybe you can get lucky and it's something simple.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
01-07-2016, 10:14 AM | #6 |
Yeah, all that. It sounds like between the pedal and clutch itself, for sure. My vote would be linkage came apart due to cotter pin. I hope you got a good night's sleep and the weather isn't too bad. Good luck with getting a part. I wonder what members are near Clovis.
01-07-2016, 11:16 AM | #7 |
Thanks y'all !!!
The nut on the linkage rod backed off. Semi fixed, enough to get going. |
01-07-2016, 03:13 PM | #8 |
Man..... Clovis, what a place to be stuck in...
Glad to hear you didn't lose the rod and assorted pieces that go with it.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
01-07-2016, 08:33 PM | #9 | |
Made it home, man that 402 is a beast of an engine. Ran between 60-70 and got 10 mpg. Thanks again everyone, this site never ceases to exceed my expectations. |
01-07-2016, 08:59 PM | #10 |
Let's see this rig!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-07-2016, 10:13 PM | #11 |
01-07-2016, 10:20 PM | #12 |
Coooooooooool!!
1972 K2500 Long Box 400/350 |
01-07-2016, 10:41 PM | #13 |
Carpe manana
From Albuquerque (Rio Rancho)? Glad that went to a member! Love my 72 C30 BB motor home. Post up pics when possible: http://67-72chevytrucks.com/vboard/s...d.php?t=510789
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-07-2016, 10:44 PM | #14 |
Carpe manana
What are your plans for the rig?
01-07-2016, 10:59 PM | #15 |
"Life is too short to drive a boring vehicle". Later, Wayne |
01-08-2016, 10:28 AM | #16 |
01-08-2016, 03:27 PM | #17 |
Keep it for a year! If people want to buy it that quickly there will be others. Don't make a 700 mile roadtrip into just a flip if you can keep it a while and have some fun with it.
I assume you're staying in the truck, or are you staying in motels? I'd figure you could be sleeping in the camper as you go...
01-08-2016, 04:26 PM | #18 |
Dang sorry about big pics
