MI '69
![]() Join Date: Oct 2004
Front leaf shackle bushing?
I'm in the process of putting a 4" lift in my 73 blazer and found that the link connecting the rear of the front leaf to the frame has a bushing that is beyond shot... I think that part is the shackle but I'm kinda new to 4wd and suspension work so I'm looking for some input on if that's correct or not. It's the bushing that actually goes through the frame... I've got all the restt of the new bushings in the lift kit...
Secondly, where a good place to get a replacement. I looked on rock auto but wasn't sure if I was looking at the right part.
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
Re: Front leaf shackle bushing?
JEGS Aftermarket: http://www.jegs.com/p/Skyjacker/Skyj...rPage=90&pno=1
LMC Truck Rubber: http://www.lmctruck.com/icatalog/csb/full.aspx?Page=62
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
The pictures should help you familiarize yourself, you can probably get it cheaper on Rockauto if they list it.
I know the pieces fit
That is the front shackle. I know Summit has them, but I'm not sure if they have them independent of a front bushing kit that would have the leaf spring bushings as well. Rock Auto might be a better bet.
![]() Join Date: Mar 2013
It seems as if you have your question answered....let's see some pics of your '73!
Check this out.
http://offroaddesign.com/catalog/FUSH.htm
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
MI '69
indeed, but where do you guys host pictures?
#8 | |
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
