Old 01-15-2016, 01:12 AM   #1
rustygmcc20
1969 gmc c2500 clutch problems
so my clutch has been acting up real bad, if i crank the truck up in neutral it will not go in gear and itll just grind, but if i crank the truck up in gear with the clutch in it'll jerk forward just a bit and then it's itll go in gear but the clutch still wont fully engage, i tried adjusting the nut on the linkage and i cant really adjust it mutch because part of the linkage is hitting the exhaust manifold, but what i could adjust seemed to make the peddle even worse and now it feels really stiff, thanks in advance for any advise yall can give
rustygmcc20 is offline   Reply With Quote
clutch
