Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-16-2016, 07:42 PM   #1
dirtyjim
dirtyjim's Avatar
left hand drill bits
since I rarely snap a bolt off in a blind hole I rarely have to drill one out but one of the tricks I learned long ago was many times the heat and rotation from a left handed drill bit will cause the broken bolt to back out on its own. if it doesn't you needed to drill a hole for the extractor any way.
it worked again this morning and I was surprised I was able to locate any of my LH bits after 20 years of not having to use them
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 01-16-2016, 09:55 PM   #2
ERASER5
ERASER5's Avatar
Re: left hand drill bits
I have a set of Ez-outs and the correct size LH drill bits. Handy.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 01-19-2016, 11:29 PM   #3
Rod Run
Rod Run's Avatar
I use LH drill bits all the time
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
