18436572
Free suspension parts off my 70' SB
I got the 4 shocks in good shape and the left and right front brake spindle units. I will never use the parts. The parts are free, just pay the shipping.
These parts were used up to about 1 month ago as i installed a 4/6 drop kit from ECE. |
67-72 Addict!
Truckhead, What all came in your 4/6 kit?. Do you have pics of it before and after by any chance?. Thanks.......Jim
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
18436572
No pics, but, from the invoice, this is what I ordered:
drop spindles disc brake conversion kit 6 lug 1.5" drop front coils 6" drop rear coils KYB front and rear drop shocks up rear shock mount relocater kit super track bar kit power brake booster upper/lower ball joints and a-arm shafts inner and outer tie rod ends/adj sleeves pittman arm/power steering idler arm front end rebuild kit and front sway bar kit Lots of stuff, but I just wanted to do it right all at once. Work is about 80% finished. Also fixed leaking steering box, thanks to info read on this board. Paul |
18436572
Hey, when I typed this out I left a lot of spaces between items, but I guess they don't show up that way on the board. Sorry for what might seem garbled info.
Paul |
