Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Old 01-17-2016, 11:58 AM   #1
grada
350 head length.
I was going to put a 350 chevy engine in my 54 chevy BelAir. I was wondering how long are the heads on the 350. My 6 cylinder head is 27 inches long.
grada is offline   Reply With Quote
Old 03-13-2016, 08:00 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: 350 head length.
20 1/2" 350 head. But the SB chev(283,302,305,307,350,400 then the bored out blocks) The block is longer then the head is you might need that info to.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
