Old 01-19-2016, 12:07 PM   #1
Lefkada
'72 C20 Lift
I have searched the forums and have called Rancho Lifts, Tuff County, 4 Wheel Parts, ORW and Moog, but still haven't found a good solution.
I have a '72 C20 (2WD LWB) with original, sagging front coil springs and sagging rear leaf springs. I'd like to get the truck 2-4" above stock height, but cannot find a method to do this. All lift kits I've found online are designed for 4x4's, which have front leaf springs, and I haven't found front coil springs with lift above stock height.
Has anyone found a solution to this? Sorry if this has been answered before.
1972 C/20 LWB, 350/350
Lefkada is offline   Reply With Quote
Old 01-19-2016, 12:12 PM   #2
hugger6933
Re: '72 C20 Lift
Big Block camper springs[or one ton] with a spacer and rearched rear leafs?
hugger6933 is offline   Reply With Quote
Old 01-19-2016, 12:41 PM   #3
Lefkada
Re: '72 C20 Lift
It sounds like this will be the best option. Are there any big issues with using coil spacers?
Old 01-21-2016, 10:37 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: '72 C20 Lift
When I did my front disc conversion on my 69 C20 I changed out the front springs. Never did anything with the rears. I installed some HD springs (P/N 2772074) bought from NAPA. Tires didn't rub at all. They were 285/70-17 tires with H2 Hummer wheels. The ride was a bit stiff, but hey it's a 3/4 ton truck. Here's a comparison of the springs:
The stock HD C20 springs are as follows:
http://www.napaonline.com/Catalog/Ca...752_0162319756
Part No.: 2771752
No. of Coils: 7.92
Free Height: 12.94"
Spring ID: 3.68"
Spring Load Height: 10"
Design Load: 2950
Spring Rate: 1016
Wire Diameter: 0.812"
The springs I put on from C10, C20, C30 from 1973-83. They are as follows:
http://www.napaonline.com/Catalog/Ca...074_0162301536
Part No.: 2772074
No. of Coils: 8
Free Height: 13.61"
Spring ID: 3.676"
Design Load: 3841
Spring Rate: 1060
Wire Diameter: 0.83"
You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are:
http://www.napaonline.com/Catalog/Ca...085_0162304063
Part No.: 2773085
No. of Coils: 7.93
Free Height: 13.34"
Spring ID: 3.65"
Spring Load Height: 11"
Design Load: 3289
Spring Rate: 1318
Wire Diameter: 0.906"
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 01-21-2016, 11:21 PM   #5
1968aj
Re: '72 C20 Lift
I just want to raise the front of my c20 to make it sit level. would these napa springs help?
1968aj is offline   Reply With Quote
Old 01-22-2016, 11:47 AM   #6
Lefkada
Re: '72 C20 Lift
This was a huge help! Thanks a ton.
Old 01-22-2016, 01:43 PM   #7
derotoreut
derotoreut's Avatar
Re: '72 C20 Lift
Should help. Brought up the front end and leveled out mine.
~ Dan
coil, leaf, lift
