Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-26-2016, 04:42 PM   #1
RyansToy
RyansToy's Avatar
Millermatic 90 vs Lincoln Mig Pak10
I have had a Mig Pak10 for about 5 years. Like it.
Always told that Millers are much nicer.
I found a Millermatic 90 used (broken) on the local forsale forum. Got it for $150. Traced the issues and it will need a new fan. So its going to be about $250 for the welder all in.
The spec's on the two welders are virtually identical; 90ish amps each, 20% duty each, 18VDC.
The miller is 80lbs, and the Lincoln is just 48lbs.
Also the Miller has 5-80ipm vs the lincolns 50-300 ipm (wire feed rate).
Any thoughts on which one to keep?
I am torn between, the lincolns newer, very clean appearance, and the Millers - been around for ages...
Thoughts?
1968 GMC truck
910 Trim (Canadian)
127" WB
3 on the Three Trans (Saginaw SM330)
250 ci L6 Engine
HEI ignition (early 80s L6)
RyansToy is offline   Reply With Quote
Old 01-27-2016, 01:30 AM   #2
slotard
Re: Millermatic 90 vs Lincoln Mig Pak10
5ipm doesn't sound right to me. A high of 80 sounds awfully low too.
I'd try running both and see which one you prefer. I suspect you'd be better off buying both and picking up something a little bigger, with gas.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-27-2016, 08:44 AM   #3
RyansToy
RyansToy's Avatar
Sorry I miss typed that. The Miller spec in the manual is 5-800 ipm.
I am going to pickup the new fan today, and try a "weld-off" this weekend some time...
1968 GMC truck
910 Trim (Canadian)
127" WB
250 ci L6 Engine
