Old 02-13-2016, 07:41 PM   #1
70c10guy
12 valve swap!
Hi all, going to try to go for a 12 valve swap within a year. I've gone to the diesel conversion section and looked through a bunch of threads and there was a specific one that was I believe a c30 and he used auto world mounts. The mounts look pretty straight forward but I just couldn't see what he did for the perches. Are they the stock ones? Built? Bought? Someone clear this up!! Thanks a bunch.
70c10guy is offline   Reply With Quote
Old 02-15-2016, 01:26 AM   #2
MaxPF
MaxPF's Avatar
Re: 12 valve swap!
Are you wanting to put a 12V in a ½ ton? If so, it is a bad idea unless you box and reinforce the frame.
1991 V1500 Blazer (Silverado), 5.9L 12V P-pumped Cummins (5x .012 sac injectors, #6 fuel plate, WH1C with external 38mm wastegate running 30psi), NV4500 with 1-⅜" input shaft, SBC Con-O clutch, NP205, HAD, 4.10 D61/14BFF spinning 37" Nitto Exo's
"I got a shotgun, a rifle, and a four wheel drive and a country boy can survive."
MaxPF is offline   Reply With Quote
Old 02-15-2016, 01:39 AM   #3
kwmech
Re: 12 valve swap!
A cummins 12v swap in the 67-72 is a really tight squeeze requiring either firewall rebuilding or stretching the front out. PLUS frame work. If I remember right the engine pushes 1200lbs with coolers and everything
Old 02-15-2016, 10:29 AM   #4
Re: 12 valve swap!
If we knew what thread you are talking about we might be able to answer your question. We need to see what you saw. It would help to now what truck you have and what engine it came with
Old 02-15-2016, 09:39 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 12 valve swap!
Do you have a picture of this truck? You are correct that Auto World has a mount kit that will work for your truck. If he used auto world mounts, he used their perches. They don't use anything OEM except a modified version of a 1st gen dodge cummins engine mount. It's poly and not rubber.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-16-2016, 04:07 AM   #6
MaxPF
MaxPF's Avatar
Re: 12 valve swap!
Have you read some of the swap threads in this section? B-series Cummins fit in a 67-72 chassis just fine. No firewall rebuilding, no front stretching, and minimal frame work.
This 1200lbs gets tossed around repeatedly on the internet. Fortunately, I have the Cummins B series shop manual in front of me. Engine weight of a 6BTA with standard accessories is 910 to 970 lbs. The 50lb variation is dependent on the exact accessory setup and whether it has a JWAC. Automotive 6BTAA's don't use the JWAC since they are air-air aftercooled, so figure 950lbs max weight. By comparison, an all-iron big block WITHOUT accessories is 685lbs and a 6.2/6.5L diesel with accessories is about 750lbs.
Old 02-17-2016, 09:38 PM   #7
Dieselwrencher
Re: 12 valve swap!
Max, it does vary but my manual shows 1020 dry and that's with no a/c comp, alt, vacuum pump/ps pump. The 950 is not accurate for a complete engine. I've weighed them a few times trying to shed some weight off one for a car.
http://cumminshub.com/12v.html
Ryan
Old 02-18-2016, 01:48 AM   #8
MaxPF
MaxPF's Avatar
Re: 12 valve swap!
My info comes from Cummins' own B-series shop manual. It says "Engine weight (with standard accessories): 6 cylinder engines ..... 410 to 440kg [910 to 970lbs]"
Perhaps "standard accessories" only means a water pump?
Old 03-24-2016, 07:03 PM   #9
70c10guy
Re: 12 valve swap!
Hi guys, sorry I haven't really been on much but his username is kobush. The install looked so clean especially the mounts. My truck is a 70 c10 original with a 307/3 on the tree. Still the 307 with some goodies and a t5 behind it.
Old 03-24-2016, 08:39 PM   #10
Dieselwrencher
Re: 12 valve swap!
That's because he used auto world mounts. Ken and Dawna are great people and provide great service!
http://www.cumminsdieselrepowers.com/
Ryan
Old 03-29-2016, 10:31 PM   #11
70c10guy
Re: 12 valve swap!
So is that set up mounts/perches from autoworld? Or mounts are auto world and stock perches?
Old 03-30-2016, 12:47 AM   #12
Dieselwrencher
Re: 12 valve swap!
Auto world does not use stock upper mounts. (Perches) You will get new fabricated upper mounting brackets, and a poly engine mount. Per side.
Ryan
Old 04-11-2016, 01:04 PM   #13
70c10guy
Re: 12 valve swap!
Cool thanks!
