Old 03-06-2016, 03:42 PM   #1
RaceProMarketing
Half-leaf rear suspension idea
Just wondering if anyone has any experience trying half-leafs and coilovers. I'm thinking that's where I'm heading with my '83. The truck is about a 5/7 drop.
My thoughts are:
C-notch ... Half mono-leafs ... Coilovers ... A panhard bar mounted from frame to some random location on the rearend ... Adding a cross-member with shock brackets to mount the coilovers.
My reasoning:
I have the leafs, I have the panhard bar, I have tons of coilovers. I'd just need to get the right springs.
Any thoughts? Warnings or Do's or Don'ts?
RaceProMarketing is offline   Reply With Quote
Old 03-06-2016, 08:32 PM   #2
Mike C
Mike C's Avatar
Re: Half-leaf rear suspension idea
Forget the the name for a leaf only supported on one side, but you used to see them on off-road buggies. CalTrac sells a split leaf to use with their tracbar setup.
But link and coil over is a better way to go everyone has decided. A flexing link through the half spring is not as effective as rigid links and separate springs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-25-2016, 11:33 AM   #3
09zkrankin
search for 1/4 elliptical suspensions. they have been used quite a bit in off road rigs, but as was said above they just dont fuction as well as a solid link, and can produce some very quirky handling characteristics.
1984 Chevy c10 lwb- project, cutting down to swb
1986 Chevy k5 blazer- sold
1987 GMC k10 lwb-sold
2011 2500HD Tow rig
09zkrankin is offline   Reply With Quote
Old 04-25-2016, 11:45 PM   #4
andrewmp6
Why not just 4 link it ?
andrewmp6 is offline   Reply With Quote
Old 04-26-2016, 02:06 PM   #5
RaceProMarketing
Because I have everything in my shop except short coilovers to do it with half leafs. I've got brackets for the frame, J-bars, shocks, (may even have coilovers). Was just gonna use the leafs as a mounting point in the front, which in reality isn't much different than a 4-link deal.
Old 04-26-2016, 02:24 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Except that 4 link bars don't bend or store potential energy like a leaf will. Half leaf is fine if you know what it will do. I don't know what your use for the truck is, just be aware that that spring setup will have an effect on axle movement in certain articulations.
IMO the others are just echoing the sentiment that a link setup has its advantages.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-26-2016, 03:38 PM   #7
RaceProMarketing
I definitely see the advantages of the 4-link, but for the money, I'm not sure. My truck isn't a show truck; it's got a 5-7 drop and is my daily driver, so I'm just trying to get is dependable and smoother. The person who started the project did little to help the ride. ... No C-notch, no drop spindle or springs up front, so just about anything I do will improve the ride. I'm just trying to do it with what I have at the shop, so I'm not spending $1,000 on one thing, when I need to spend it on the front suspension and the overall dependability of the truck. Thanks for all the feedback. -RH-
