Old 03-08-2016, 02:29 AM   #1
crakarjax
crakarjax's Avatar
Addco 239 rear sway bar?
Anyone use the Addco 239? I can't find install pics anywhere but it's listed as a 73+ Truck bar. I also can't find dimensions, anyone know how to locate sway bar dimensions by chance?
http://www.summitracing.com/parts/aco-239/
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-08-2016, 07:52 AM   #2
PGSigns
PGSigns's Avatar
Re: Addco 239 rear sway bar?
That bar is for a C30 leaf spring truck so I don't see it coming close to fitting a C10 coil spring setup. Addco does make a C10 rear bar part number part number 954. They also have a handling book you can down load that is a very good read. About a 100 pages. Look under the tech tab on there website.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-08-2016, 11:40 AM   #3
crakarjax
crakarjax's Avatar
Jimmy
I did order the handling book, in paper! I stare at a screen all day so paper is a nice change of pace. How did you know what the application was for that bar? Any way I can find out the spring rate?
I did spot that bar but the bar arms seem too short which makes me think it has a high spring rate. I'd have to mount it in a location not as designed because my truck is lowered and I think the short, straight bars would make that tough. I wish they would publish the specs on their bars!
Old 03-08-2016, 01:31 PM   #4
PGSigns
PGSigns's Avatar
You could call Addco on both the rate and the design of the C10 bar to see if it works OK with a lowered truck. I looked it up in the Addco catalog as the picture looked like a leaf spring bar for a top mount spring. They do a good job of matching there bars in sets front and rear. For what you are trying to do it would be a good option to get the pair. Also if you put a long panhard bar on the truck it really helps the roll center and made a big improvement in the handling on my 66.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
