Old 03-13-2016, 12:03 AM   #1
rsgriffith821
Thumbs down 02 4.8 trans in an 02 5.3
I have a 2002 chevy 1500 2wd extended cab with the 5.3 and a bad transmission. I have a good 4l60e from the same truck in the same year with a 4.8. but when i plug the info for both trucks into the parts comparison checker, it tells me it wont work but i cant get a straight answer for why. Does any one know the differences between the two trans in 2002?
rsgriffith821 is offline   Reply With Quote
Old 03-13-2016, 06:54 PM   #2
clinebarger
Re: 02 4.8 trans in an 02 5.3
No worries....They will swap with no issues.
clinebarger is offline   Reply With Quote
Old 03-13-2016, 06:59 PM   #3
rsgriffith821
Thank you for the reply. Just curious now but you you happen to know why it flagged it? Is there anything at all I need to look closely at like sensors, pigtails, or bolt patterns before I hoist it up under there?
Old 03-13-2016, 08:04 PM   #4
clinebarger
The only thing I can think of is the Torque Converters may be different....
All 5.3L trucks have a "TMBX" converter 1500-1700 stall, Though most 4.8L engines also got a TMBX.
Some 4.8L got a "TLBX" 1800-2000 stall. Would still work fine on a 5.3L with a little boost in performance.
There is sticker on the converter cover that has the code....Post the code please.
2002, 4.8l, 5.3l, difference, transmission
