68 k20 carb to aircleaner spacer questions
I have a 1968 K20 with the 327/quadrajet 4BBl . It has a standard aircleaner assembly. between the carb and the aircleaner is a spacer about two inches in height.
does any one have pictures of one I can compare so I get the right one. I'm shopping for one. seller's ask me if it has a fitting or tube on the side for a PCV valve.... or not. my trucks PCV valve is already hooked up else where. So I'm assuming I need the spacer with OUT the PCV fitting on the side? Pictures of a correct 4bbl spacer would be wonderfull. |
Re: 68 k20 carb to aircleaner spacer questions
It's not a pcv fitting!
It's an air fitting. To supply filtered air to one valve cover. Do you have an air fitting/tube on one cover? |
oh! now I dont know. gonna half to look again
