GMCDAC
NP205 torque mounts
Hi K5 folks, it's been a long time coming but I'm getting a bit of momentum going on at least putting our '70 Jimmy back on the road. It will still be a work in progress too, but driving it again is still most important.
Last weekend I finished a pretty thorough rebuild of the transfer case and the newer style TH350 adapter I got from Turp McSpray a couple of years ago. Anyway I have the new rubber crossmember mounts but have been hitting dead ends trying to find rubber torque mounts. There are neoprene ones that don't cost much and are common. Anyone know where to get rubber ones or would it be ok to mix the two types and just order a set of neoprene ones? Here's a couple pics of the fresh 205, please ignore the date stamp in the pics, my camera was off by a year and didn't notice it until after I downloaded them. Any input will be appreciated. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
Re: NP205 torque mounts
I've got a set of neoprene if you want them
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
GMCDAC
Thank-you Jim, I'll send a PM. I can't come up with a reason why the neoprene torque mounts would not be compatable with the rubber mounts, just didn't know.
DAC
Just give a little time, as the next 5 days are booked, I'm guessing they'll fit in a 5.00 flat box
![]() Join Date: Nov 2007
Careful mixing and matching. It'll cause different flex points and stress. Same goes for your motor mounts and tranny mounts. Motor and tranny should be all rubber or all poly, but not mixed.
When you say "neoprene", I assume you mean "polyurethane". If you use polyurethane mounts on the transfer case torque arm it won't cause any problems if you have rubber mounts everywhere else. All it's going to do is reduce the amount twist in the engine/transmission under heavy load.
#7 | |
#8 | ||||
GMCDAC
Thank-you all for the help and advice. DAC
For what it's worth, I'm running rubber motor and transmission mounts and polyurethane on the torque arm.
#10 | |
GMCDAC
Thanks---DAC
X2, I feel better offering them to you
