03-21-2016, 09:21 PM | #1 |
Tell me about seats.......?
I got this '70 K5 CST......body is rust free (repaired where necessary)....decent paint..
I'm gonna get GrumpyOldMan to build me an interior.....he's really close to me and does incredible work...! OK I have two sets of seats the blue style came in it as I bought it........the bare one is out of a '71 back side..........one has a larger back rest and a metal cover.... blue one latches on the right...........other one.....center latch the floor mounts match at the front....but obviously the rear does not and there are no holes existing in the center.........that's no obstacle..... just wondering which one will sit better/firmer/more comfortable? the foam in the blue ones is worn out...gone in the others gonna take the brackets and get zinc plated with gold chromate.......one set of seats will be "discarded"....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-21-2016, 09:56 PM | #2 |
Re: Tell me about seats.......?
The blue seat is a cst sport seat and the other is a utility bucket seat. The blue seat is the upgrade and has side bolsters built into the foam. The utility bucket is pretty much flat with no bolster. I prefer the comfort of the blue sport bucket myself.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
03-21-2016, 10:16 PM | #3 |
12.75" vs 15.25"
As already mentioned the metal backed seats are called utility buckets. The other seats are the conventional, or sport buckets. They are not simply a swap out affair. The holes for the utility buckets are 15.25" apart, while the holes for the conventional buckets are 12.75" apart. The utility buckets are less popular, but that doesn't mean there is anything wrong with them. They are a little wider so it's tough to squeeze the console between them, but it has been done. The latch that you have on the blue seat is different from my Blazer's latch.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-22-2016, 07:30 AM | #4 |
thanks for the replies..........the blue ones will get the makeover.......
03-22-2016, 07:50 AM | #5 |
Both seat types for 69-70 latch is off to the side as shown with the sport bucket set you have and both seat types for 71-72 latch in the center as shown with the utility bucket.
03-22-2016, 07:52 AM | #6 |
Looks like your sport seats may be missing some seat springs not sure the wood should be there.
03-22-2016, 08:15 AM | #7 | |
Now I need to find out if/where I can get some springs.....?
03-22-2016, 08:51 AM | #8 |
My 70 K5 has the utility buckets also, they were redone at some point, I'm not crazy about the seat cover and I have a center console that squeezes in tightly I don't even have to bolt it in. I do sit kinda high in them, I think they added a little too much foam?. I'm going to keep em cuz that's what came up my truck originally
03-22-2016, 11:31 AM | #9 |
03-22-2016, 12:04 PM | #10 |
Hey you're right........My '06 Z06 has balsa wood floors....!
03-22-2016, 07:57 PM | #11 |
You can get springs anywhere that deals in upholstery. Once you take the cover and plywood off you will see where the spring are supposed to clip into. Messure the distance across and multiply by 5 for each seat. Add a few inches to that measurement. The spring comes on a coil so you will need a length to tell them for how much you need.
The sport buckets will give support keeping you from sliding around on turns and such, are significantantly more desirable and easier to get covers for.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-23-2016, 07:19 AM | #12 |
Thank you my friend.........
I have no doubt that GrumpyOldMan can git-r-done........... I'm not stuck on a "factory" look..........I want to go black vinyl with blue top stitch and some kind of blue/black cloth insert on the seating surface. The rear seat is in great shape except for the arm rests.....like to put heaters in it..... Also which vendor here has the best door panels with the woodgrain insert?
04-28-2021, 03:48 PM | #13 | |
Active Member
04-28-2021, 09:20 PM | #14 |
Carpe manana
It’s seems to me that 71 was the last model year for utility buckets. I’ve yet to see a non-CST 72 that has metal backed utility buckets. I think GM used a sport bucket for all K5s in 72 with the CSTs getting upgraded vinyl.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
04-28-2021, 11:55 PM | #15 |
Active Member
Makes me wonder if they swapped out the original seats for older utility seats and modified the original brackets to work. It’s a hack job so maybe that’s the case
04-30-2021, 08:12 AM | #16 | |
I have long since redone the entire interior changing it to black and putting new seat covers along with new springs and foam....it's better than new now.
