Old 04-01-2016, 08:42 PM   #1
2tontruck
CPP 5in rear coils and a 1.5 lowering block who runs this set up?
Working on the suspension for the 72 Suburban and I was wondering if anyone else is running this set up and can provide me with a little feedback. I have a set of 5 inch drop coils, 1.5 lowering block and a ECE track bar kit. I am curious about if these items work together well together. I have a 3 inch spindle in front along with a lowered coil spring as well. As always I appreciate any and all feedback.
2tontruck is offline   Reply With Quote
Old 04-02-2016, 01:46 PM   #2
2tontruck
Re: CPP 5in rear coils and a 1.5 lowering block who runs this set up?
Anyone????
Old 04-03-2016, 11:27 PM   #3
Tork?
Based on what I've read it should work fine together.
Because I have 5" CPP springs and want to do the blocks too I'll be following and hoping for pics
Tork? is offline   Reply With Quote
Old 04-04-2016, 01:49 PM   #4
juddss
Following
juddss is offline   Reply With Quote
Old 04-07-2016, 12:28 AM   #5
BigMike
BigMike's Avatar
I had CPP 5" springs with 1" blocks in the rear with CPP trac bar and had no issues at all. I don't really think 1/2" would make any difference, you'll be fine.
Now I have bags w/ the 1" blocks that go WAY lower than the 5" springs + 1" blocks did.
BigMike is offline   Reply With Quote
Old 04-18-2016, 09:31 AM   #6
69vetteside
69vetteside's Avatar
i had 5in and 2in blocks and all worked fine.
now am about to run 6in with 2in blocks with notch.
69vetteside is offline   Reply With Quote
