Old 04-02-2016, 09:09 PM   #1
rmc70
Rear leaf springs
OK guys, I'm kind of new to these trucks and I have a question. I have a 1970 GMC 1500 long bed. Why do some of these trucks have coil springs and some have leaf springs in the rear end? If I want to level the truck out and bring the rear end down pretty much even with the front end, will removing a leaf out of rear springs do it or what other options are there? Would like to thank you in advance if somebody could give me some answers.
rmc70 is offline   Reply With Quote
Old 04-03-2016, 10:39 AM   #2
rmc70
Re: Rear leaf springs
Come on guys, don't be shy.
Old 04-04-2016, 08:19 AM   #3
panhandler62
Java Mechanic
panhandler62's Avatar
Getting a flip kit to set the axle on top the leafs is probably better than stripping a piece of the spring pack out.
Pulling a leaf out will lower the rear of the truck, but it will also change the spring rate which will impact handling and load.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 04-04-2016, 08:44 AM   #4
rmc70
Why does some of our trucks have leaf springs and some have coils?
Old 04-04-2016, 09:37 AM   #5
Mike C
Mike C's Avatar
GM built the trucks both ways. As a general rule, GMC came with leaf and Chevy with coil in the 1/2 and 3/4 ton trucks. But you find GMC with coil and Chevy with leaf. All C30 trucks were leaf.
On my '70 GMC C2500 I used ECE shackles to bring the back down more level but not lose any towing/hauling capacity. On my current '69 Chevy C10 leaf truck I used a DJM flip kit. Draw back to the flip kit is you don't have a lot of control of how much drop you get. On my truck is was just over 7" which may be more than you want...
I have 2 1/2" disc conversion spindles and 2" drop springs on the front for the look I wanted.
You can buy drop springs in different heights depending on how low you want to go. Leafs are just a lot more expensive than coils so make sure and know where you want to be before opening the old wallet.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-04-2016, 10:56 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Everything I have seen, Chevy came standard with coils and GMC came standard with leafs. Either brand could be special ordered with the opposite setup.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-04-2016, 10:16 PM   #7
rmc70
Thanks a lot fellas, Your knowledge helps a bunch. I'll have more questions I'm sure.
Old 04-08-2016, 01:52 PM   #8
ksshane
ksshane's Avatar
Unless you plan on dropping your front end as well. I dont recommend doing a axle/leaf swap. It just lowers the rearend way to much if your keeping the front stock.
For example. On my truck I have the 2.5 drop spindles and 3" drop springs in the front, and only the axle swap in the rear. The rearend actually sets about a 1/4 of an inch lower than my front end (measureing from the top of the wheel well to the ground). Granted my leafs are the original. So a new set of leafs will raise the rear end up a little, but not much.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 04-13-2016, 07:10 PM   #9
3757chevy
3757chevy's Avatar
Big Block Chevy's came with leaf, also.
3757chevy is offline   Reply With Quote
