Old 04-07-2016, 12:19 PM   #1
71ChevySS(straight6)
Arrow Thinking about building a rat rod with a 366. Worth it or no?
Hey guys. I've done a little reading on 366 big blocks, but there's not much to read.
My girlfriend is addicted to Crosleys (the pre-war to 1952 microcars), and her mom is trying to buy her and I a little station wagon to chop up into a rat rod. I might have a 366, 5-speed, and 2-speed rear axle at my disposal (along with the heavy front axle). Would it be worth it to build my own frame, slap the drivetrain and axles on there, and drop the chopped up body on? Total vehicle weight would only be probably 2,500 lbs. I know the 366s are torque monsters. What do you guys think about them? Would it be a good engine in this application? Input? Advice? Thanks!
'71 Custom-10 2wd longbed, 250 inline-6, NP 435 four-speed. Medium Bronze Iridescent. Farm truck deluxe.
Rat rod build: 1949 Crosley Station Wagon body on 1993 Dodge D350 chassis, Cadillac 500 powerplant.
71ChevySS(straight6) is offline   Reply With Quote
Old 04-07-2016, 12:24 PM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Thinking about building a rat rod with a 366. Worth it or no?
Apsolutely positively NO. They are school bus, dump truck motors and need to stay that way. They are tall decks so certain parts will be a little more expensive and harder to pick up used. It's all about money in and what you get back. On that light of a car, I'd do a 350/350 combo. Cheap parts for days and a weight savings.
prostreetC-10 is offline   Reply With Quote
Old 04-07-2016, 12:30 PM   #3
I have a whole donor truck, an '87 GMC 7000. I could pull all the parts I want from that truck. It has the cast iron headers, I'd just need to make a side-exit exhaust. I wouldn't have to do anything to the engine, it runs perfectly fine the way it sits. The idea of the rat rod project is to go with as little expense as possible. Going out and buying a performance 350/350 combo would completely throw that away.
Old 04-07-2016, 01:34 PM   #4
61K10
61K10's Avatar
Do it!! thats what rat rods are all about-------------Axles might be a tad wide lol.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-07-2016, 02:50 PM   #5
storm9c1
*** That's interesting ***
storm9c1's Avatar
I've seen some crazy rat rods. My favorites have always been ones built out of heavy duty trucks and combos that everyone else says is dumb. I like the idea of repurposing an otherwise useless piece of old iron. So go for it. The risk is there -- if something breaks, it may be harder to fix. But until it breaks, there's no reason not to use it, except your time to build it of course.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 04-07-2016, 03:50 PM   #6
cadillac_al
I could sell you a nice Crosley engine if you need one. The old 366 trucks with glass packs still sounded good around the yard and going down the road imo. If it was free I would use one.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-07-2016, 04:28 PM   #7
jjzepplin
jjzepplin's Avatar
I think free stuff should be used. I thought of this same idea as 366's can be had for almost nothing. My 307 can be abused by many peoples opinions but it was just sitting there free. $100 dollars worth of oil pump, timing chain,and freeze plugs and there you go. Should run long enough to get my 383 going. Then its blown tranny time and etc etc. But running moving vehicle for now.
And just think about the towing capability of the 366.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-07-2016, 06:54 PM   #8
That's the idea, have the axles sticking out way past the body :P
I love the crazy rat rod combos too. They just look badass!
I don't think I need a Crosley engine, but I can let my girlfriend know you have one for sale. She has five other Crosleys lmao
It won't be free, I made an offer of a thousand for the engine, trans, and axles. But it does sound awesome and run awesome in the truck it's in right now!
Like I told cadillac_al, it wouldn't be free, but it would be unique and awesome.
Old 04-07-2016, 08:34 PM   #9
franken
The truck engine, and axles will weigh more than the rest of the wagon...
That 2 speed rear will also have ratios that make the freeway a place you don't want to drive.
What trans?
franken is offline   Reply With Quote
Old 04-07-2016, 08:53 PM   #10
cadillac_al
$1000 is kinda high. I see low mileage 454's out of RV's pretty often for under $1000.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 04-07-2016, 11:31 PM   #11
Captainfab
60-66 Nut
I will have to agree with prostreetc-10.
In stock form the 366's are turds. Certainly not what I would call a torque monster. I think a 350 would make close to as much torque. Every 366 I have been around, when the time came for a new engine, it was replaced with a 427. Plus then the big 5 speed and 2 speed rear. To package all that together with a tiny Crosley body on top is going to look goofy at best.
For $1000 you could buy a decent running car or squarebody truck and have everything you need that will be much easier to build and make look decent.
Old 04-08-2016, 12:23 AM   #12
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
350? C'mon. Bout the most boring engine you could put a in Rat rod.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-08-2016, 12:26 AM   #13
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Wouldn't be super fast, but it would be Different and would be Cool. Why not use something you have? So I go along with the crowd that says "DO IT!!!!" 366 would be cooler than a boring overused 350.
Old 04-08-2016, 06:30 AM   #14
D13
D13's Avatar
You will quickly find that while it looks cool it will be no fun to drive. Motor is designed to run all day at 2800-3200 rpm, bore is too small for bigger valves, heavy pisotns, etc. In the top range of the 2 speed you will still get passed by everything. Steeering on those axles is poor. tires brakes etc $$$. So if your urge is to build somehting that is basically cool looking but you don't want to drive, go for it. If you want to build a tow rig Crosley then go for it, mount a 5th wheel hitch and be happy. If you want something to cruise in put your Crosley on a 4.3 S10 chassis and get a big grin going.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-08-2016, 08:15 AM   #15
cadillac_al
Yup, no doubt about it, the 366 is the red headed step child of big blocks. As a former farm boy I have had C65's going right side ways through mud holes in 3rd gear with the glasspacks blattin'. I didn't have tachs in them but I'll bet they will rev to 5k rpm. Diesels just sink in the mud because they don't have any wheel speed and no rpm range.
I still wouldn't pay too much for one. A lot of farm vehicles are very low mileage though. If you buy a low mileage one it would last a very long time.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 04-08-2016, 03:33 PM   #16
Tom
driving is in my blood
Tom's Avatar
If the engine was free, use it. The axles and trans have no place in a street car that weighs under 6000lbs. Since its not free, scrap this idea. Put a small block in and call it whatever you want to feel unique. Tell everyone its a 265.
Old 04-08-2016, 03:39 PM   #17
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just cuz you can... don't mean you should.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-08-2016, 05:21 PM   #18
storm9c1
storm9c1's Avatar
With the peak power down low, that would make a good engine in front of an overdrive. You could undergear that thing and cruise at 1500 RPM at 65MPH I bet with how light it would be.
How to do that, I'm not sure. I think the 366 has a standard bolt pattern, so any Chevy transmission should bolt up. Or add an OD unit instead of the splitter. I'd be tempted to try it. I would definitely try to take advantage of the torque and lightness of your chassis. Ditch the governor if it has one. Don't get too attached to the axles, they may hold you back. If you want a light-duty dually with the HD appearance, find someone with a Dana 70U and highway gears (ie: 3.07 or less if you can find it!). Folks usually want to give those away. And forget trying to rev it and lay tire. It won't be a good setup for that. But you can use the torque wisely and still have fun.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 04-09-2016, 10:49 AM   #19
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'm assuming the 366 is like my GMC's 305E V6. Torque down low and not fast by any means. I will say though that with the little mods I did to my V6 it pulls 100% better than before. It'll lay tire rubber no problem at 2000-3000 rpm. lol Have bumped it up to 3K, but nothing higher. Buddy of mine has a propane powered 366 in a school bus.....moves that thing along with no problem.
Old 04-12-2016, 09:06 AM   #20
68Gold/white
I was going to put a 366 in my 67. Decided no to. A lot of customizing needed.
There's a lot of good things, like a Holley carb fits the intake, trans bolt pattern, motor mount holes all same as a 454/350.
The 366 that I DID have, now gone was out of a bus. It had the high mount water pump (the fan position was about a foot higher than the standard water pump fan. I guess trucks use the standard water pump.
You HAVE to use a 366 water pump because of the water pump bypass. I've seen one tall deck 427 in a pickup with a standard pickup/car water pump. A bypass setup was corn cob engineer ed to function, it was not pretty.
1987 was the first year for fuel injection, although not all 366's were injected that year, is yours injected? If it was, that would be awesome, although creating another problem, delivering fuel to engine w/ correct pressure, and return line to tank...
The 366 was engineered by old timey thinking, some good, some not.
The small bore allowed tight control of the combustion event, more effecient, especially under heavy load, less likely to ping, Controlling ping in an engine that's over taxed is important. 366 has same stroke as the 396 and 427, 3.75, excellent torque producer!
The 3 compression ring was not really needed, but may have been needed for production line machining tolerances, who knows, it made the pistons a lot heavier.
If you have the standard water pump, your only big hurdle is adapting the radiator hoses down to standard car/pickup hose sizes. The hoses used on 366's are way bigger that standard car/pickup hoses. There's a company that makes these adapters, was an ad in a magazine long time ago. Adapters could likely be made at local machine shop.
If you have any other questions, let me know. I WAS going to do this, to much life happening at that time, I sold the 366....
68Gold/white is offline   Reply With Quote
Old 04-13-2016, 12:47 PM   #21
prostreetC-10
My Carbon Footprint
Believe me.....the ONLY reason I suggested that is because I was mearly guessing that money could be an issue which is why he wanted to try the original package. You know me.....it must be north of 454 inches to be interesting.
Old 04-13-2016, 12:49 PM   #22
prostreetC-10
My Carbon Footprint
Gary
The great Chris Rock once said "Just because you can drive with your feet don't make it a good f**king idea!!".
Old 04-22-2016, 12:40 AM   #23
What trans?
It'd be the truck five-speed. I've never had the truck past third gear, as the soybean tender bed on it is kinda brittle and can't be roughed around and jostled or some of the brackets will break. But, from what I can tell, the trans has pretty good ratios, and with the splitter on the rearend, I feel like it'd have a decent highway gear. Better than my '71 C/10 anyways.
I have no idea where. Maybe in your area, but in central Kansas I can't find a decent 454 that doesn't need a major rebuild for under $1200 or so. But remember, the $1000 would be for engine, trans, and axles.
Then why was the 366 only used in school buses and dump trucks if it doesn't have a lot of torque?
427s are bored out 366 blocks.
I think the industrial look with the Crosley body will look cool.
EXACTLY my thoughts.
350s are nice, but way overrated. Everyone uses them.
But just slapping the body on an S10 chassis is too easy and too boring!
It's currently used as a soybean tender truck, but it doesn't leave the lot, we just load beans on it and weigh them across, the farmers come in and load out from it. So mileage should be fairly low, I've never bothered to look. I'd be getting the engine, trans, and axles for the price I'd pay ($900-1000).
It won't be a racecar by any means. Just a cool cruiser. Why do you think I should go the boring route that EVERYONE goes?
Gary
Again... Wanting to be unique, and not boring.
Definitely gonna get rid of the governor. However, I have to disagree slightly, I've watched a video of a 366-powered C65 do a burnout. lol thanks for the actual advice though, instead of just telling me to be like everyone else and buy a 350.
You're absolutely correct, lots of lowend, and not a lot of speed. But, I've never had it split in fifth. Like I mentioned previously, I have only had it in third gear buzzing around the lot.
Old 04-22-2016, 12:49 AM   #24
You're awesome! lol
I have the whole truck (rather, will have). Meaning I have the truck radiator, truck hoses, everything I need. I just need to adapt those items to fit on a custom frame.
Mine is not fuel injected, no, just carbureted.
Old 04-26-2016, 08:50 PM   #25
gvw5400
gvw5400's Avatar
GO for it!, rat rods are a concept most folks will never understand. Medium duty "junk"
can be a ton of fun! A baby Rat motor can run pretty hard for less cash than the belly button crate 350.
All the Best,
Dirk
gvw5400 is offline   Reply With Quote
366, big block, rat rod
