04-19-2016, 10:19 AM | #1 |
Cpp "bent" trac bar
I have the cpp "bent bar. truck is lowered with 3' drop springs and a 1" block
when installed the bar does not sit level as the stock bar does. does it matter? It is a street strip truck. the drive-shaft occasionally rubs on the cross-member.(i'm guessing when launching) and is more to the right and not on center with the stock bar. so i'm guessing i need the adjustable one. anyone have any insight to this? |
04-20-2016, 09:34 AM | #2 |
Re: Cpp "bent" trac bar
bump
04-20-2016, 10:23 AM | #3 |
Java Mechanic
The track bar does center the rear end so you may need to adjustable bar to get set up correctly at ride height.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
04-20-2016, 10:49 AM | #4 |
if i use the panhard bar. i can center the rear end, but the cpp bar. does not sit level when installed
04-21-2016, 10:18 AM | #5 |
bump
04-21-2016, 12:38 PM | #6 |
You might try posting pics of the bar installed at ride height, and if you get some measurements of how much clearance there is on each side of the driveshaft to the crossmember.
With the longer tracking bars (like what you have), the arc is less than it would be with the shorter factory panhard bar. This would create less lateral movement when you hammer down and the rear end squats. So this is a step in the right direction. The cpp tracking bar is probably not level by design, and I wouldn't expect it to be a problem. If the driveshaft isn't centered, and it is rubbing, than an adjustable bar could fix that. There are other brands of tracking bar systems that lower the mounting point further below the frame, probably for the purpose of keeping the bar more level, and minimize that lateral movement. |
04-25-2016, 02:09 PM | #7 |
i reinstalled it. its not too bad. except the bar isnt short enough to center the axle. its off 1/4'
