04-24-2016, 07:00 PM | #1 |
6.0 LSX twin turbo 72 c10
I am starting a build on a truck I've had since I was 14 years old, I would love to hear ur opinions and ideas are welcomed. The first pic is how it was when I tore it down for this build.
04-24-2016, 07:06 PM | #2 |
Re: 6.0 LSX twin turbo 72 c10
04-24-2016, 07:34 PM | #3 |
laying low
Here ya go.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-24-2016, 08:05 PM | #4 |
The cab
04-24-2016, 08:06 PM | #5 |
The bed
04-24-2016, 08:10 PM | #6 |
Mock up engine "stock 6.0L" with speed engineering headers and a PTC build TH400 Trans with pro mod drum reverse manual valve body and Trans brake.
04-24-2016, 08:16 PM | #7 |
Sat the engine and Trans in to do a lol mock up. Not the right placement yet but I'll get there. Also waiting on a couple BW S366 turbos and a BTR cam. I need the turbos for mock up also.
04-24-2016, 08:17 PM | #8 |
And another
04-24-2016, 08:27 PM | #9 |
Cool so far! Any plans to paint the frame, or leaving it bare? Just asking, I don't know your goals.
04-24-2016, 08:32 PM | #10 |
If you want I think "wasted income" on this sit has that very combo putting out big numbers and sounds awesome goin' by my house!!It is in a 2wd 70?? blazer??
Good luck on the build! Gotta do something with those shortbeds.LOL! No harm intended they are a sweet ride!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
04-24-2016, 11:22 PM | #11 |
Looks like the start of a nice build! Im planning on running those headers on my truck once i put a 4.8 or 5.3 in it. Have you put the master cylinder and booster (if youre running one) on it to see if it clears or not?
04-25-2016, 06:05 AM | #12 |
Looks like you're well underway.
Turbos are too much fun. Drive like stock, absolutely brutal power on the boost. I've posted this before, but I'll say it again. Everyone is quick to spend money on the short block/engine when really the keys are: - Fuel system - Engine management (I'm not a fan of the stock pcm for boost) - Tq converter - Trans You've got a great start with the ptc converter and TH400. It's gonna be a mean machine once you get it going!
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
04-25-2016, 12:15 PM | #13 |
Yes I will be cleaning and painting the frame but for mock up and what I may need to weld I want to wait til the cab and bed are at paint for all of that.
As for the brake booster I haven't got that far yet but will b looking into that. Last edited by GRN72; 04-25-2016 at 12:19 PM. Reason: Add |
04-26-2016, 06:16 PM | #14 |
What fuel system are u running "Heavymetl" and are u happy with it. I've been reading and everyone says somthin different.
04-26-2016, 09:51 PM | #15 |
Sweeeeeeeeet
04-28-2016, 07:20 PM | #16 |
Came home to a couple parts today. Custom cut Brian Tooley cam lifters pushrods titanium retainers locks keepers and valve springs.
05-05-2016, 07:42 PM | #17 |
Got my lil helper cleaning up the trailing arms. I plan on boxing and dimple dieing them. Also goin to widen the wheel tubs so pulled the old ones out
05-05-2016, 07:43 PM | #18 |
Wheel tub
05-05-2016, 09:50 PM | #19 |
Subscribed
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie |
05-06-2016, 09:54 AM | #20 |
05-06-2016, 12:51 PM | #21 |
cool truck excited to see the twin turbos!!!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
05-26-2016, 08:13 PM | #22 |
Haven't had a lot of time to work on the truck work has been crazy, this will b a slow build by the way. But did get a couple new parts.
05-26-2016, 10:17 PM | #23 | |
100 micron pre-pump filter Holley 12-1800 fuel pump 40 micron post pump filter Holley Boost Reference FPR -10an feed -8an return. Holley EFI Holley 120lb injectors Overkill? Probably. But on E85 I'm most certainly not running out of fuel under boost. As for street driving, 10,000+ miles on the setup and so far so good. I could have went cheaper but I just didn't want to deal with a fuel delivery problem and associated headaches.
09-23-2016, 08:49 PM | #24 |
Got a lil more kick up done and a couple more parts.
Posted via Mobile Device |
09-23-2016, 08:53 PM | #25 |
Started a lil fab work.
