Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-18-2016, 05:55 PM   #1
KyleSeal
KyleSeal's Avatar
Painting Engine Block
Had my engine block tanked a few months ago and in the mean time (every week or so) I'll put a pretty liberal amount of WD-40 on it each time.
Is there any way to remove all of this WD-40 from the block where I need to paint? I need to still pressure wash the block in order to get it clean completely.
About the pressure washing - how do I go about this? Do I pressure wash into the water jackets? Wont the water get stuck in there and create rust?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 05-19-2016, 01:14 PM   #2
NJ C10 Guy
Re: Painting Engine Block
I used greased lightning and simple green to clean off my block after hitting it with a wire wheel, but I never sprayed it with wd40. It was just dirty. I would suspect you can use either of the above to get the wd40 removed.
NJ C10 Guy is offline   Reply With Quote
block, chevy, engine, orange, painting
