Old 05-20-2016, 08:41 PM   #1
Alex V.
Alex V.'s Avatar
'03 1500HD Idler/pitman/center link bad?
I'm getting ready to do ball joints on my FIL's '03 1500HD 4x4, looking over the rest of the suspension for anything else that needs done, and I find that, while applying force to either wheel with hands at 3:00 and 9:00 (side to side) the center link (solid bar that attached to the drag link and pitman arm, that the tie rods thread into on each end) will rotate over 1/8 turn on its joints allowing toe-in to change drastically. I'm not familiar with this front suspension system, but that seems wrong. Is the center link supposed to be held basically rigid by the drag link/pitman arm, or is it correct for it to rotate on its joints some?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-20-2016, 11:35 PM   #2
twinturboc10
Re: '03 1500HD Idler/pitman/center link bad?
The center link should be fairly rigid. I had the same truck, and had to replace both the pitman arm and idler arm at about 75,000 miles because of the wear.
twinturboc10 is offline   Reply With Quote
Old 05-21-2016, 07:28 AM   #3
Alex V.
Alex V.'s Avatar
I suspected that. Thanks!
Alex V.
