05-24-2016, 10:57 AM | #1 |
c5500 350 to 6.2 swap
Hey everyone, I will be buying the 72' C5500 as soon as my car sells. It has a 350 Chevy in it backed by the sm465, and my buddy has a 6.2 diesel for little to nothing. This isn't my first time around the 6.2's and 6.5's, i know they are no power house, but thats fine. What i need to know is what will I need to swap the two? Will the flywheel off the 350 bolt up to the 6.2? And il have to run a separate g.p. relay system.
05-24-2016, 12:34 PM | #2 |
Re: c5500 350 to 6.2 swap
I'm not sure about the flywheel, you may want to check in the diesel section on this forum regarding that part. I do know that the bell housing bolt pattern is the same and it is a direct bolt in on the motor mounts. Make sure to share some photos with us when you get it.
-Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
05-24-2016, 12:48 PM | #3 |
Thanks for the reply, I was unaware we had a diesel section, i guess ill have to look for that.
05-24-2016, 04:22 PM | #4 |
I am pretty sure that the 6.2 is externally balanced having rebuilt two of these. I recall the flexplate having a large weight spot welded to it. you would have to have a flywheel for a 6.2. I am also aware how gutless these are and would suggest a duramax instead. You would have 3x the power and the same mileage.
05-24-2016, 05:11 PM | #5 |
I'm not a big fan of Duramaxes, but if I did that, would it bolt up to my transmission? And If i swapped in a more modern diesel engine, it would be a Cummins or Powerstroke swap. Im looking for this to be a pretty simple swap. And i always liked the 6.2 idi's for some reason.
05-24-2016, 06:44 PM | #6 | |
You can tell I don't know my diesels. |
05-24-2016, 08:10 PM | #7 |
This probably isnt the place to start a discussion on the big three's diesel motor choices. It will lead to an argument like always. I like powerstroke and cummins, and thats what i work on the most, duramax's are fast, but they just aren't at the top of my choice list.
05-25-2016, 02:35 PM | #8 |
One thing to watch for on that swap is the flywheel. Your truck should have the 13" clutch. (Easiest identifier for that is the bellhousing is bolted to a plate that is bolted to the block.) This may or may not give you a problem. I know a fellow who told me years ago that he did the same thing on a newer truck and it worked fine. But I never saw it first hand. I would in your case, put the turbo setup off of a 6.5 on your 6.2.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
05-25-2016, 02:47 PM | #9 |
What about a 6.5? Will a pre 93' 6.5 bolt right up? Obviously ill need some wiring and small stuff, but i mean is it just like the 6.2? Bellhousing and motor mounts the same?
05-25-2016, 11:13 PM | #10 |
Up through and including 93 are mechanical engines. 94 started the electronic injection. Exteriors are the same.
