06-14-2016, 08:14 PM | #1 |
Don't use lock washers and other stuff you didn't know
I was looking into thread locking compounds and ran across an engineering firm that studies bolt loosening and failures. The takeaway is that lock washers actually decrease the preload curve of fasteners! It's mentioned on the site also that regular washers also have a detrimental effect, which is disappointing because I use them to avoid scratching up paint when fastening. I'm not sure if the use of thread locking compound would make up for using flat washers in that case.
http://www.boltscience.com/pages/hel...ingwashers.htm http://www.boltscience.com/pages/vibloose.htm
1968 LWB C20 / AC / Wood Bed |
06-14-2016, 08:32 PM | #2 |
Re: Don't use lock washers and other stuff you didn't know
Ahh nuts!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-15-2016, 07:52 AM | #3 |
What you did there. I see it.
My brother sells fasteners and anything else a maintenance crib needs. According to him, split ring lock washers are a tool of the devil. And has the data to prove it. Take close look at grade 8 bolts. On the bottom of the bolt head, there is a raised portion. Using no washers, the hex never touches the part. Only the smooth ring, like a built in washer. A lock washer completely negates that as well as cuts into both surfaces. That's just one example. And his hacksaw blades? He can tie them into a knot, then untie them no worse for wear.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-15-2016, 08:42 AM | #4 |
anything you'd ever want to know about fasteners. lots of math.
https://standards.nasa.gov/file/515/...token=cXwrFsu2 |
06-15-2016, 10:29 PM | #5 | |
06-15-2016, 11:16 PM | #6 |
I have real world experience to prove those work from the top down types wrong. I don't need to say they are wrong, maybe they are right. But, all I know is in my years I have never had these washers cause any detrimental effect. So, even if they are right by their data, it's a moot point. Fact is, it really doesn't matter. Weren't engineers involved in the design of these washers and all the products they've been used on since before corn flakes were invented?
06-16-2016, 12:20 PM | #7 | |
I'm leaning toward this stuff on all my nuts; I would like to try the gel compound but it doesn't call out oil resistance and I think that's a big bonus in my application.
https://www.amazon.com/gp/product/B0...d4b1c6519c0709 This is the gel stuff, and it seems like a better deal per ounce really. https://www.amazon.com/gp/product/B0...1e43ce26309a7f Quote:
https://www.google.com/patents/US514...D2AYkQ6AEIPzAF How do you know these had no detrimental effect? Did you have side by side nuts and compare the rate at which their tension decreased over time? I'll take empirical evidence over anecdotal every time.
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 06-16-2016 at 12:26 PM. |
06-16-2016, 01:59 PM | #8 | |
Nutshell version of NASA's view on split-type lock washers: NASA Fastener Design Manual RP-1228 - Page 9-10: "The lockwasher serves as a spring while the bolt is being tightened. However, the washer is normally flat by the time the bolt is fully torqued. At this time it is equivalent to a solid flat washer, and its locking ability is nonexistent. In summary, a lockwasher of this type is useless for locking." http://ntrs.nasa.gov/archive/nasa/ca...9900009424.pdf |
06-16-2016, 03:25 PM | #9 |
Thanks! What do you guys use then, if anything? I've heard that a properly torqued nut shouldn't come loose but have seen evidence to the contrary. As I understand it, thread locking compounds work by filling in non-contact areas in the thread interface, increasing friction and ensuring that vibration doesn't cause intermediate loss of friction that can result in fastener turnout?
06-16-2016, 04:07 PM | #10 |
Depends on application really but for flight-certified hardware (stuff that goes into space ) ALL fasteners have a required torque specification and we then use everything from chemical thread locking compounds, deformed threads (nuts), cross-drilled fasteners & safety wire, mechanically-captive fasteners (specialized inserts) to poly-lock nuts to keep stuff where it's suppose to be. Loose nuts, washers and bolts floating around inside the International Space Station can make for a bad day.
And no, I have never seen a split-type lock washer used as a locking mechanism here. Last edited by Willie Makeit; 06-16-2016 at 04:14 PM. |
06-16-2016, 09:51 PM | #11 | |
Clarification: I used the "wrong" wording in my first statement, and that's probably what is causing friction. I would have edited it but it had already been read and responded to. I should have said "prove it doesn't matter" in most practical applications. That is the point I was making. My experience has been they help hold things tighter than without. To what degree I don't know. I also have learned to use thread lock in crucial situations. The stroked 26 year old Harley I've ridden for 13 years (on that engine) has a solid engine mounting. It is a bone shaker. Harley used lock washers throughout, even on things such as switch housings, but no thread lock. The engine cases use lock washers and compound, along with other cases and major mechanical components fasteners. But not everything on the bike. Things hold together well. The problem I have is metal fatigue. The sheet metal wants to split and even had the tab that mounts the belt guard on the swing arm break at the weld. Both fenders have cracks in the flat sides. There was a chrome cover for the rear master cylinder and it split around the bolts. The lower chrome steel belt guard split in half, and I had long low pipes that extended 6" beyond the rear hub. Both pipes were splitting around the diameter just beyond the rear mount, so I cut them shorter. All these fasteners had held tight with no compounds, only lock washers.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-17-2016 at 07:19 AM. |
06-17-2016, 01:41 PM | #12 |
The data a does not say lock washers make things looser. It says it makes the bolts weakER. ER, as in somewhat, a little, measurable. Not weak as a cat, or loose as a goose. Lock washers are made to gouge, that's why they work. They dig in like studded snow tires. That's good and bad depending what you are doing.
My "made in China" charcoal grill had split washers for every nut and bolt. Yes I used them. A nylock would melt out, a pinch nut would be a royal pain to use, and locking compound melts out. Split washer was the best choice for that application.
06-20-2016, 08:27 PM | #13 |
I think a distorted thread lock nut would work better but they also cost a whole lot more.
06-20-2016, 11:22 PM | #14 |
Definitely cost a lot more since the lock washers were included in the cost of the grille. How much better than "works just fine" do they need to be? I talked this weekend to a guy in his 80s who runs Model Ts on thousands of mile tours and has done so for many many years. He's driven to Alaska in one, and he says BS. He was an Air Corp pilot in his younger days and is 3rd generation coal mining business. They use lock washers on their equipment and he told be to ask what you guys thought about that.
He's had this one for 60 years. Solid rubber tire with 5th wheel:
06-21-2016, 12:43 AM | #15 | |
Since you know a coal miner that swears by lock washers are you saying we should ignore the "experts" with "evidence" gathered in a "scientific" fashion? Everyone is welcome to their opinion but let's keep this thread fact-based as that's what it was intended to be.
06-21-2016, 02:13 AM | #16 | |
now that is a cool truck! idc what brand name it is.... solid rubber for carrying the weight and a 5th wheel ohhhh. i do have a soft spot for the looks of the very early trucks.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-21-2016, 03:32 AM | #17 |
There's values for every aplilacation. If you dont wantscratch your
There's pros and con for every apilickation .use what you want your not gunna die . This topic is to vague to get into .You never said what you where tightening just worried bout paint? |
06-21-2016, 06:38 AM | #18 | |
06-21-2016, 06:49 AM | #19 |
Sorry for the hijack. Just taking a moment to inform
It's a '26 Ford Model TT. The TT came with solidd rubber rear and pneumatic fronts. Pneumatics were new to the world and not trusted to carry but so many pounds, and solids assured the load got there w/o a hitch. The solids were added to the front to better equip the truck for heavier hauling per the fifth wheel. They didn't run to fast back then, but roads were rough and there were no shocks! This one actually had add-ons called Hasslers. They were just coils mounted at an angle side to side, mostly controlled body roll since the transverse springs created that action over bumps. This truck had them front and rear. There were also aftermarket friction shocks.
06-21-2016, 12:41 PM | #20 |
20' Daredevil (Ret)
I see what you didd there!
06-21-2016, 02:26 PM | #21 |
next time you're piddling around with a car that was built since the mid 80's, notice how few split washers (if any) are used. technology transfer & research are great things when funded by the American tax-payer.
