70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Rear End Ratio Question
Does anyone know what the stock rear end ratio is on a 1973 C20 Burb with a 454 and TH400 trans.? The Burb has factory A/C and posi traction as a spid option. There is no trailer tow package option on the spid. I'm hoping for a 3:54 like the 72's had.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Rear End Ratio Question
What does your glove box say for an RPO code?
GQ1 -- AXLE REAR, STD RATIO GT4 -- AXLE REAR, 3.73 RATIO GT5 -- AXLE REAR, 4.10 RATIO GU4 -- AXLE REAR, 3.08 RATIO GU5 -- AXLE REAR, 3.23 RATIO GU6 -- AXLE REAR, 3.42 RATIO G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Thanks for the reply. I don't know when GM starting using the black and white RPO labels but I think in the later 70's. attached are a pic of the spid and the window sticker. The Birb is for sale and I'm thinking of buying it but am not a friend of 4:10s with a 454.
1/2 ton or 3/4 ton?
I'd be looking in the 3.00-3.50 range
According to:
https://www.gmheritagecenter.com/doc...t-Suburban.pdf 3.73 was stock, with 3.21 or 4.10 as optional ratios. I highly doubt 3.21 with the RPO trailer package; would seriously believe that its 4.10........ jmo
1994 C1500 rclb 1988 C1500 rclb 1969 ES5500 B E A S T 1983 C10 'farm truck' 1976 K20 Suburban 1984 K10 Suburban 1981 Jeep CJ5/350 Vortec 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
The 3.54 you refer to for '72 was an L47 option (not RPO) - they were ONLY available on CE20 Burbs with 400 sbc.
Those gears were in a "Dana 5500" rear axle. Hen's teeth. My '72 K20 has 4.10 gears; Eaton HO52 rear & Dana 44 front. You always could switch out the gear if it is 4.10 and not 3.73 -jessayin'
