Old 07-14-2016, 06:10 PM   #1
Alecmcski
Question Chevy Apache body to 99-07 4x4 frame
Hey there, I'm looking for some information on a body swap. I can get a great deal on an 03 gmc reg cab long box 4x4. The only problem with the truck is the body is shot. So what I'd like to do is get 1958-59 chev or gmc apache and swap it on to the frame of the newer truck.
if anyone has any info on this swap or has ever done it any information would be greatly appreciated.
Alecmcski is offline   Reply With Quote
Old 07-15-2016, 02:28 AM   #2
andrewmp6
Re: Chevy Apache body to 99-07 4x4 frame
Can you weld and trust your life on your welding skills?A easier swap would be http://www.e-zchassisswaps.com/kit.php?category=5
andrewmp6 is offline   Reply With Quote
Old 07-15-2016, 09:00 AM   #3
Alecmcski
I can weld and I'd really like to do it with a newer truck. I like the idea of a modern drive train and suspension, I can also get one for dirt cheap.
Old 07-16-2016, 02:52 AM   #4
andrewmp6
You will have to shorten the frame to the wheel base of the older truck,Make every body mount and bed mount and make the core support work.And thats just getting the body on the frame.Its a really big job not many have done it because of that.
Old 07-18-2016, 02:56 PM   #5
rgunlock
rgunlock's Avatar
Also compare the frame width. I've got a 59 chev stepside I was considering putting on a 93 4x4 frame. The 93 frame was quite a bit wider so as an example would not fit between the steps on the bed. Looked to be a lot more fabrication than I had in mind so I scrapped the idea.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
4x4, apache, apache 4x4 conversion, conversion
