Old 07-24-2016, 05:50 PM   #1
1-Ton
1991 chevy v3500 3+3
1-Ton is offline   Reply With Quote
Old 07-24-2016, 07:21 PM   #2
1-Ton
Re: 1991 chevy v3500 3+3
New engine for Chevy 1991 V3500
Old 07-24-2016, 07:24 PM   #3
1-Ton
4L80E/NP205 almost ready to go,
Old 07-25-2016, 12:50 AM   #4
bilfman
bilfman's Avatar
Love it.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 07-25-2016, 07:55 AM   #5
1968vetL-71
Junior Member
1968vetL-71's Avatar
Wow!! Nice looking Crew!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 07-25-2016, 07:44 PM   #6
Marshy
Looks nice. What are the specs on the engine?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 07-25-2016, 08:33 PM   #7
1-Ton
The engine is just a GM Goodwrench new crate engine. It is only rated at 200 HP with 300 Foot Pounds of torque. The heads are center bolt swirl ports. The compression is 9.25:1. I did take the stock cam out and put a mild COMP computer controlled cam into it (PN# 12-304-4).
I also bought a bored out TBI from VIC Morse, with an adjustable fuel pressure regulator. I had the stock aluminum intake bored out to match the TBI. I added a 5-QT oil pan to it as well, along with a steel sleeved oil pump drive.
I will get some mid-length headers for it in the future, and do some custom tuning to the OBD-I ECM as well. all of these mods should add another 50 HP, at least, to the stock engine output.
Old 07-25-2016, 08:35 PM   #8
crewcabshorty
crewcabshorty's Avatar
Is the trans and case original to the truck?
crewcabshorty is offline   Reply With Quote
Old 07-25-2016, 11:08 PM   #9
1-Ton
Yes. This truck has the original 4L80E transmission and 205 transfer case it came with from the factory. The 4L80E/205 combo was only available for 1-year...1991.
Old 07-25-2016, 11:36 PM   #10
1-Ton
Originally Posted by bilfman View Post
Love it.
I see in your sig you have a 1979 Crew Cab with a 4L80E/205 combo transplanted into your rig. Are you running it with a stand alone computer?
Old 07-26-2016, 02:18 AM   #11
bilfman
bilfman's Avatar
Yeah I am using a tci stand alone unit, it has been flawless for years. I was fortunate enough to find a 91 trans and tcase, it has been awesome.
