Old 07-29-2016, 07:42 AM   #1
'76 Big Block
Rear End
I've got a lot of play in the rear end on my '76---- pretty good "clunk" when putting it in drive from park, or drive to reverse.
I've found a rear end out of an '88 that's supposed to be 5 lug, in decent shape.
My question is, will the '88 rear end fit under my '76 in terms of spring perches, lug patterns, etc.
Anyone made a swap like this?
BTW---my truck is short step side 1/2 ton.
'76 Big Block is offline   Reply With Quote
Old 07-29-2016, 08:05 AM   #2
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: Rear End
Before you go swapping out rear ends, i'd first check the u joints (if you haven't already). Thats usually a major culprit of the notorious clunk! If it is in fact the rear end i would think a 73-87 1/2 ton rear would be plentiful in the junk yards down there. I'm not sure on the 88' model for a direct swap. I would think you would run into shock placements, brake line sizes, etc..? Usually the newer body style meant they changed a bunch of other stuff up. Good luck tho!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 07-29-2016, 08:26 AM   #3
74CustomK20
74CustomK20's Avatar
Re: Rear End
Have to start moving spring perches and shock mounts... Also don't know if 76 was standard or metric brake lines, but I know 88 is metric... My 79 was metric.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 07-29-2016, 08:37 AM   #4
Alex V.
Alex V.'s Avatar
Re: Rear End
I believe they changed the springs pretty substantially for the GMT400 platform. I'm not positive but I wouldn't get my hopes up. And if the diff. is wearing out it should be making a pretty noticeable noise, especially at low speeds - Turbo Hydramatics can shift pretty hard (especially reverse, at least on a 400) and U joints are worth checking.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 07-29-2016, 10:44 AM   #5
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: Rear End
Pull the cover and check the backlash between the ring and pinion gears. They are probably ok. A lot of times it's just worn spider gears causing the slack, and they are easy to replace.
Like these: https://www.summitracing.com/parts/yga-16043
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 07-29-2016, 01:27 PM   #6
bbbc10
Diggin The SquareLife
Re: Rear End
gotta make spring mounts shock mounts brake lines etc....an it be to wide...if ur gonna swap rear ends try to find a impala ss rear end
bbbc10 is offline   Reply With Quote
Old 07-29-2016, 02:19 PM   #7
Jaysonb
Jaysonb's Avatar
Re: Rear End
My rear end had a ton of play, it would bang hard when shifting out of park. New spider gears fixed it right up, pretty cheap, and easy to install.
Jaysonb is offline   Reply With Quote
Old 07-29-2016, 05:21 PM   #8
friscobob
Re: Rear End
My 81 has a 12 bolt that is not metric in the rear, fronts are.
friscobob is offline   Reply With Quote
