08-11-2016, 07:55 PM | #1 | ||
"I ain't nobody, dork."
Garbage Rocker Panels
This is a snippet from my build thread and wanted to get some input. Basically should I continue with what I have? Or pull it off and start again with a different brand of rocker panel... since not everybody is following my build thread... I wanted to toss it up here in the open forum... please read on!
Metal thrashing mad! I have been beating my head against a wall with this passenger side outer rocker. I see and hear about cats replacing them like... "super easy, didn't have to modify anything..." Not the case with mine. I found out after I have this thing halfway installed and have had to refabricate the entire front of it, that I have panels made by "Dynacorn". Apparently they are garbage. Well... FML. In the pics you'll see how far I had to bend the damn thing away from the pillar to get it to line up with the door and the fender. Plus like I mentioned above I had to refab the front of it to get it to even mate up with anything. I had to make a relief cut towards the inside near the door lip that I will have to "massage" into place with strategic welds and hammer shots. I've also had the door and fender off 300 times and aligned over and over again. So I'm either going to quit with this one, and remove the welds I already have in it and junk it for panels made by a different source... or I can make this POS work and then get a different brand panel for the drivers side. Glad I started on the passenger side so it won't pi$$ me off every time I opened the door! Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
08-11-2016, 08:23 PM | #2 |
Re: Garbage Rocker Panels
I had similar troubles. I ordered three complete sets of rockers and none of them were worth a #@%#. I ended up modifying mine pretty close to what you did. It's just they way it is unless you want to pony up for a set of NOS rockers, they are out there if you search long enough. Get -R- done and move on......
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
08-11-2016, 09:11 PM | #3 |
I don't want to sound like a jerk, and I feel your pain but I think if you made about three more cuts your mighty close. Looking at the pics and remembering what I did on the last one I did, I made about three relief cut and two pie cuts and quite a bit of hammering to make me happy.
And as to speaking of NOS OE panels I remember doing rockers on a truck I gave my brother many years ago before I cared about this body style[I got in to them in his memory]They did not fit much better than some I have used lately. But back then the dealer had a pile of them seems like I gave like $25 bucks for them with my discount. Hang in there and keep at it and it will work out. don't be afraid to cut it you can weld it up and don't be afraid to bend it you can make it right again |
08-11-2016, 09:30 PM | #4 | ||||
Gary
08-11-2016, 10:01 PM | #5 | |
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
08-11-2016, 10:11 PM | #6 |
I hate to say this, but for the 3 trucks I have done the DRIVERS side has always been harder!
Keep at it, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
05-15-2017, 02:51 PM | #7 | ||
For an update on a rocker panel that actually fit very well. Here are a couple links to posts from my build thread with pics.
http://67-72chevytrucks.com/vboard/s...&postcount=269 http://67-72chevytrucks.com/vboard/s...&postcount=270 Gary
05-15-2017, 03:13 PM | #8 |
Thanks for the tip on the double label Dynacorn. Think I'll just avoid them if I can.
05-15-2017, 03:46 PM | #9 |
Good to hear they fit a lot better. I have the key parts ones for "when it's time."
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-15-2017, 06:22 PM | #10 |
Great follow up, and valuable info for those of us that need to complete this fun job.
I got an older set of aftermarket rockers from a guy I know, they sat for about 20 years in his shed. I guess if I run into trouble with them Ill know now to right away abandon them and search out some of the proven ones. |
05-15-2017, 06:38 PM | #11 |
At the body shop.
I'll need rockers and cab supports, so not looking forward to either one.
" That didnt make it any newer " " Dont antique the equipment " |
