Old 08-27-2016, 09:24 PM   #1
hotrodron
Check engine light
Since i put on a kn filter and intake tube my check engine light comes on goes off 50 miles goes back on code checker said lean burn left bank now code checker said error no reading what do you think is going on
hotrodron is offline   Reply With Quote
Old 08-29-2016, 11:56 PM   #2
hotrodron
Re: Check engine light
Bump it up
Old 09-04-2016, 04:03 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Did any of the MAF sensor wires get bumped or messed up when you put your K&N on or did anything get bumped putting your intake tube on? If not I don't really see how putting on that stuff could have affected anything. Have you recently done anything else to the truck. What year make model and drive train on the truck?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-05-2016, 01:18 AM   #4
hotrodron
Im going to try some of the spray maf sensor cleaner on it i may have over oiled the air cleaner been told that will cause the problem thanks for the help
