Where to get longer wheel studs
I'm looking for longer wheel studs for my 80 c10 the current 1 1/2 inch studs are to short. I'm looking for some in the 2 1/2 inch range. Where are you guys getting them? I've tried looking at summit,moroso, ect but can't seem to find any that are 1/2-20x2 1/2 with a .530 knurl.
Thanks for any suggestions! Carter |
Re: Where to get longer wheel studs
You may not find the longer studs in the knurl diameter you need. You may have to have the holes enlarged to accommodate the larger knurl size. I had a machine shop do this to my original front rotors several years back.
For press in usually you can only find 3" and then will have to cut them down to the length you want.
Look on ARP's site and Morrso's, but have a feeling you will have to get 3" and trim them, I had to for stock rotors back when I ran them.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
