Old 09-14-2016, 05:56 PM   #1
1969 Project
1969 Project's Avatar
Rear shock mounts
Anyone have any easy tips on how to get rid of the rivets on a stock shock mount so I can install the shock mount relocater?
1969 Project is offline   Reply With Quote
Old 09-14-2016, 07:30 PM   #2
PGSigns
PGSigns's Avatar
Re: Rear shock mounts
I use an air chisel to knock the heads off and drive the rest through the frame. You can also drill the head off. I drill a 1/8" hole through the center first then run a 3/8 through it and that get most of it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-14-2016, 11:26 PM   #3
1969 Project
Thanks Jimmy. Do you have any tips on how I can get the rusted coil spring bolts loose?
Old 09-15-2016, 06:54 AM   #4
PGSigns
PGSigns's Avatar
I spray them with PB Blaster and let em sit. Hit them with the impact and half the time they come off the other half they break off. Either way it does not take long. I always put new bolts in no matter what since for my stuff they are 50 years old and thats long enough and time to retire them.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
