Old 10-07-2016, 11:30 PM   #1
ck5566
Casting #'s on Pow. Strg. Gear Box
I am looking at a Power Steering Gear Box that the owner says it for the 67-72 trucks. Can the numbers on it tell what it is? were is whats on it, pictures below. Thanks in advance
ck5566 is offline   Reply With Quote
Old 10-08-2016, 11:10 AM   #2
B. W.
B. W.'s Avatar
Re: Casting #'s on Pow. Strg. Gear Box
2WD or 4WD? My gearbox has a date code 260 9 (260th day of 1969)
and 7802644 (same #s you have above) my truck is a 1970 K20
Can't see much from the picture
Bobby
B. W. is offline   Reply With Quote
Old 10-08-2016, 01:04 PM   #3
65 C20
7802644 is the P/S box that I used on my 65 C20.
It has the standerd threads on it, not the metric version that came later.
65 C20 is offline   Reply With Quote
Old 10-08-2016, 09:38 PM   #4
ck5566
Here is more pic's.
Old 10-10-2016, 12:01 PM   #5
ck5566
What is your Gear Box Case's Julian Date Code? mine showed (1 236) Aug. 24,1971 or 1981, and what is your top Aluminum Inspection Covers Julian Date Code? mine showed ( 254 8 ) Sept. 10 or 11 1968, 1978, or 1988 depending on the Leap year or not.
Old 10-11-2016, 11:38 AM   #6
65 C20
Not sure of my date codes.
I just ordered a re-manufactured box for a '70 chev.
Cardone 27-7501. Casting # 7802644.
Fits and works properly.
Cal.
Old 10-11-2016, 10:57 PM   #7
ck5566
Another question that I have, is both the pow. strg. box case casting numbers the same as whats on the top alum. inspection cover casting numbers providing they were both married together from when the pow. strg. box was being put together at an assembly plant? Just curious as both mine are different, or by default are they different or should they be?
Old 10-11-2016, 11:00 PM   #8
ck5566
Bobby
Mine is a 2WD
Old 10-12-2016, 11:30 AM   #9
65 C20
They will be different.
The casting # on the box is for the box.
The # on the alum. cover would be the part # for the cover.
If they both had the same # then they would be the same part.
Different parts different #'s.
If you are unsure about the condition of the box that you are looking at I would just get a reconditioned one from the parts store.
I found a used one cheap and used it for my core charge for the new one.
Old 10-12-2016, 06:33 PM   #10
ck5566
Thanks for the Number differences info. I did go ahead a buy the gear box for $50 and if its NG at least I have a core, most places want $75 and up for a core. thanks again
Old 10-16-2016, 08:26 PM   #11
ck5566
This posting is for 65 C20 or who ever. Here is some pictures of what I have and will be using for the Driver Side top mount Alternator with Brackets and the Power Strg Pump & Brackets that will be right under the Alternator. Also all the pulleys I have to be used.
Old 10-17-2016, 11:59 AM   #12
65 C20
They all look good but untill you do a mock-up and see if all the pulleys line up you won't know for sure.
You have a 305 and I had a 283.
As far as I know if you use the P/S box with casting #7802644 you will need a Moog pitman arm #K6361, That is what I used.
As for the P/S pressure hose I used Edelmann #70917.
Like I said earlier my truck is a '65 with a 283.
Is there anyone else on here with a 305 in a '67 - '72 truck that would be able to verify what worked for them ?
Cal.
Old 10-17-2016, 06:06 PM   #13
ck5566
Cal.
Cal, the Moog Part # K6361 from Rock Auto says it doesn't exist. Do you have the #'s changed around or just wrong #'s.
Old 10-18-2016, 12:51 PM   #14
65 C20
Ya, sorry about that.
The pitman arm is really Moog #6131.
Surprised no one else has come on from your year forum.
Cal.
