10-15-2016, 11:56 AM | #1 |
BlahBlahBlah
Diy 4x
I was looking at their B52 kit and saw it came with 6 inch shackles. But there isn't anything I could find that gave the actual final lift specs. So I'm curious if anyone here has used this kit and what was the lift.
I can always email them, but sometimes getting an answer from someone that has actually used the kit IRL is best. |
10-15-2016, 01:33 PM | #2 |
Re: Diy 4x
I had it on my 77 1 ton I've been working on. It was an actual 4" with 6" shackles but I never drove in it.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
10-15-2016, 03:48 PM | #3 |
BlahBlahBlah
Re: Diy 4x
Four inch isn't a lift size I ever wanted but my 68 GMC had one on it when I got it and I have gotten used to it. I know I like the ride better on the longer springs. Those were on my 73 K20.
10-16-2016, 08:15 AM | #4 |
Currently Blazerless
Re: Diy 4x
I think anywhere from 4" to around 8" should be achievable using stock springs. There is such a wide variation of the 52" spring from different years and models it just comes down to knowing which spring you need to get the 4" lift you want. I've thought about using them myself but would like to hear from others who have used them on the 67-72 trucks to get their impression of them.
And from the looks of the front hangers I doubt you'll be able to mount tow hooks?
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
10-16-2016, 08:24 AM | #5 |
Re: Diy 4x
The kit itself doesn't give you any lift. All it is is a mounting point for the springs. Since 52s are longer than 48s (or whatever yours is), the mounting points are moved. Lift is whatever springs you use, but as mentioned is gonna be different with all the different springs out there. Generally it's 4"....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-16-2016, 04:00 PM | #6 |
Re: Diy 4x
Ive got the B52 kit on the '63. It may not be apples to apples but here is all of the info as best as my memory will allow. You're results may vary. LOL
I used the B52 kit with the 6" shackles , front core support bushings from a '72, springs from a '73 K10 (5 leaves I think) and poly bushings that came with the springs. I measured before and after and appeared to raise the front of the truck by approximately 1/2 to 3/4" from the stock location. The springs have very little positive arch but are not flat or inverted by any means. I did use the multiple bolt holes to adjust the axle 1" forward from stock so that the wheel was better centered in the fender well. As far as how the ride is now compared to before with the 45" springs? There is no comparing. My old set had an add a leaf which while giving a little lift, made the ride unbelievably stiff. My barometer is that my wife will now ride in it and has even asked to drive it a few times since the swap. I really like the new set up although I would STRONGLY recommend a front sway bar if you do not already have one. Pucker factor of 12 without the bar! If you run poly bushings in your springs I would also recommend the greaseable bolts as mine squeak like crazy unless its raining. Drives me crazy. The tow hooks will work if you trim off the little gusset in the front and re drill the hanger for the hooks. In retrospect, I would have had DIY4x4 send me the hangers without holes so that I could have drilled my own where necessary. Their hardware is second to none and IIRC, the brackets were at least double the thickness of the stock hangers if not thicker.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
10-16-2016, 04:04 PM | #7 |
Re: Diy 4x
If you would like, I could take some pics and measurements since I have the sheetmetal off of the front end as we speak. Let me know.
Chris
10-16-2016, 06:52 PM | #8 |
Re: Diy 4x
Oh crap I just realized you were asking about the front...
10-16-2016, 08:46 PM | #9 | |
Re: Diy 4x
I can say when I originally had 4" lift HD springs in my front it handled great and was really planted to the road. Now I have the Skyjacker Soft Rides and it's kinda mushy for my liking, front end bobs, but it still stays where I put it and tracks nice. I had considered this kit myself awhile back. I was thinking about this because I am contemplating going back to HD front springs. How's that gear vendor... I'm getting one after I rebuild the 465 and 205! I recently chickened out of buying a used on ebay! Aside from that hijack I am also interested in finding out about the DIY B-52
White K20 |
10-16-2016, 10:59 PM | #10 | |
Re: Diy 4x
http://67-72chevytrucks.com/vboard/s...d.php?t=670974 Sorry for the hijack CG.
10-16-2016, 11:48 PM | #11 |
BlahBlahBlah
Re: Diy 4x
Interesting. So I could possibly get away with only having a 2.5 inch lift depending on what springs I use. Ill have to email the guy and see what he recommends.
Im not going to do anything with my truck yet. Just determining which truck I want to keep, and some of that depends on how much I need to spend on each to get it to where I want. Would love to see pics of the one that doesn't have the front sheet metal on. |
10-17-2016, 07:00 AM | #12 |
Re: Diy 4x
Diy4x stuff is top notch. The spring arch and shackle length will determine the lift. I don't see any reason they you couldn't use a shorter (4") shackle is you wanted to get a lower ride height. give them a call, there very helpful over the phone.
I have the DIY4X rear shackle flip with 63" springs and love it. very well built. I plan on doing the b52 kit over the winter |
10-17-2016, 08:52 AM | #13 |
Re: Diy 4x
Shorter shackles may hit the frame.
10-17-2016, 12:03 PM | #14 | |
Re: Diy 4x
10-20-2016, 01:12 AM | #15 |
Re: Diy 4x
I would agree. I only have approximately 2.5" between the frame and spring eye. If I had to guess, my shackle angle would be 5 deg to the rear from center. Not a whole lot I don't think.
10-20-2016, 01:22 AM | #16 | |
Re: Diy 4x
I would agree with downey as well. My front end is all DIY while the rear 63" spring swap is 1/2 DIY and 1/2 ORD. While the ORD stuff is pretty bulletproof, the DIY stuff looks as if it should be on a bomb shelter. Each of the front leaf hangers weighs around 10 -12 lbs. Nice stuff with good hardware.
10-20-2016, 01:26 AM | #17 |
Re: Diy 4x
Just looked at the pictures again and my frame looks like Swiss Cheese! I removed the brackets for frame paint. All but 3 or 4 holes there end up with bolts through them LOL!
Heres one last pic of the 6" shackle..
10-20-2016, 06:49 AM | #18 |
Re: Diy 4x
looks good. I bet a 4" shackle would clear fine as the factory shackles are pretty short. But a longer shackle in the back is better for your caster angle anyway.
63genIII - off topic; did you experience more wheel hop/ axle wrap after putting the 63" springs out back? I added soft 63" springs & 4.56 gears w/ posi. this combination created a wheel hop problem. Last edited by downeyballz; 10-20-2016 at 06:59 AM. |
10-20-2016, 07:18 AM | #19 | |
Re: Diy 4x
Wheel hop or axle wrap hasnt been a problem at all. I still have the factory overload in place, no lift block, 4:11s and a 5spd. Not that it's a common occurrence by any means but the 35s can be hazed with no noticeable hop.
09-08-2017, 01:06 PM | #20 |
BlahBlahBlah
Re: Diy 4x
Finally actually getting around to decided my spring issue. I "joined" DIY4X so I could get an email response, nothing yet. And havent gotten through to a person yet via phone. I watched his vids and one Q and A vid he has for the B52 kit says, no the kit itself does not cause a lift, its the springs. Next line he says so if you are using a stock spring you will get 4 to 5 inches of lift ... LOL, Im confused. Id love to have about a 2 to 3 inch lift all around with the longer springs for more comfortable ride, but I think its time to start shopping for the best deal on stock style springs with the exact lift I want.
I have the stock rear spring for my truck. Probably cheaper to just install those with some blocks and get a 2.5 inch lift springs for the front. My 4x4's wont see any crazy off road stuff. I think his stuff is more suited to the real off road crowd anyway. Thanks for all the input on the B52 stuff https://www.youtube.com/watch?v=cS2YLzBpy94
09-08-2017, 05:32 PM | #21 |
Re: Diy 4x
He says no lift if using STOCK front springs, but 4-5" if using STOCK rear 52s.
09-08-2017, 09:13 PM | #22 | |
Re: Diy 4x
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
09-08-2017, 09:26 PM | #23 | |
Re: Diy 4x
Yours is moved rearward. Can you elaborate on that at all? -Brad
09-08-2017, 09:50 PM | #24 |
Re: Diy 4x
60-66 4wd trucks have really short front springs, like 45-46" or something like that. So with the 52s up front, using the stock hole for the shackle would put too much angle on the shackle, so had to move it rearward.
09-08-2017, 10:03 PM | #25 | |
Re: Diy 4x
i have been a customer and 100% happy with his stuff and custom made to my spec stuff .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
