Old 10-24-2016, 11:12 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
Updated FUSE BOX?
I need to update from the original fuse box in my son's '63 stepside.
Can anyone recommend an affordable updated FUSE BOX?
'63MurderTruck is offline   Reply With Quote
Old 10-25-2016, 07:29 AM   #2
Indian113
Indian113's Avatar
Re: Updated FUSE BOX?
If you are handy and can do it Check out the company called Rebel Wire. I rewired my 64 in 2 days and haven't had any problems in 5 years. I just used a battery charger for my 12 volt power until I was sure it All worked right.
Indian113 is offline   Reply With Quote
Old 10-25-2016, 10:39 AM   #3
Figuarus
Figuarus's Avatar
If you're handy AND cheap, use a fuse block out of almost any newer junkyard vehicle with the blade-style ATO or Mini-ATO fuses.
I used a block out of my old 96 S10 Blazer, and just made sure to transfer power one wire at a time. The beauty is that now, evertime I make a junkyard run, I make it worth my while by grabbing a few car's worth of fuses. An additional bonus is that if I wanted to, I can expand and add more power to my fuse block in the future as I have more slots to add wires. Just make sure to keep any wires/connectors you remove from the block. They have a small retaining pin in the block that you can push with a small pick to remove the pin.
i'll take some pictures later. im at work right now.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-25-2016, 11:00 PM   #4
'63MurderTruck
Thank you.
The pics will be very helpful.
Old 10-25-2016, 11:08 PM   #5
'63MurderTruck
Will this fuse box work?
http://www.ebay.com/itm/12V-10-Way-L...xXQLBG&vxp=mtr
or, would this one be better?
https://www.summitracing.com/parts/PRF-70207/
Obviously, I have no clue when it come to electrical stuff.
Thanks in advance.
Old 10-25-2016, 11:44 PM   #6
64shortbox
64shortbox's Avatar
This is what I went with 21 circuit 17 fuses all wiring is marked every 6" or so stating what it goes to. Like right rear stop, radio, fuel pump, right front power window, head light, etc., etc.
Just because the wiring is there you don't have to use it, like the power windows etc. I still haven't installed it yet. I did open it up and check it out though and it looks good.
http://www.ebay.com/itm/21-Circuit-E...dUW139&vxp=mtr
64shortbox is offline   Reply With Quote
Old 10-26-2016, 12:11 AM   #7
'63MurderTruck
Thanks for the reply.
I don't need anything near that elaborate, and I don't need the wiring harness. I just need a very basic and affordable 'fuse box'
Old 10-26-2016, 07:45 AM   #8
Sik5chevy
I used painless in my other truck and it was simple and easy. It is straight forward, but you also have tech support if you need it.
Sik5chevy is offline   Reply With Quote
Old 10-26-2016, 09:03 AM   #9
thomas_a_reed
thomas_a_reed's Avatar
I found this one on amazon pretty basic kit "Wisamic 10 Circuit Basic Wiring Harness Fuse Box Street Hot Rat Rod Wiring Box Car Truck 12V" haven't installed it yet but it looks pretty well made and labeled..
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 10-26-2016, 10:00 AM   #10
LVPhotos
LVPhotos's Avatar
Speedway Motors has several. This is the bare bones that I have. Electric fan and horn relays built in. $144.00 12 circuit.
http://www.speedwaymotors.com/Speedw...ness,2352.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-26-2016, 10:12 AM   #11
jayoldschool
Moderator
If you just need a fuse box, grab one out of a basic car at the U Pull It yard. No need to spend lots of cash on a new part. Wire up the circuits you need.
jayoldschool is offline   Reply With Quote
Old 10-26-2016, 10:21 AM   #12
Figuarus
Figuarus's Avatar
63murdertruck, I forgot to take pictures last night, but i'll take some this afternoon. Sorry!
2013 Malibu LTZ
Old 10-28-2016, 10:18 PM   #13
Figuarus
Figuarus's Avatar
Ok. First and foremost, I'm sorry this took me a bit to do. I've been working and doing a lot of favors for other friends. I managed to finally take some pictures tonight. Again I apologize if they're not clear. You can see where the original harness from the truck was wired into the new fuse block using butt connectors. The new fuse block was mounted to the firewall with a simple L bracket. The beauty of this setup as you can see is that it is expandable for future wiring needs. While it is not labeled, the fact that there are very few circuits from the factory means that if anyone is blown you can see it almost right away. I hope this gives you some insight on how to do this mod.
2013 Malibu LTZ
