Old 10-26-2016, 01:31 PM   #1
Korted
67-72 LS Swap motor mount options
I am in the process of rebuilding a GM LM7 (5.3L) to put into my 1968 C10. I currently have the 1968 stands (single hole), but no motor mounts. What is the best mounting option? I am considering using 73-87 stands/clamshell mounts/dirty dingo adapters, but am not sure how this affects engine location and height. If you have experience, please share. Thanks!
Korted is offline   Reply With Quote
Old 10-26-2016, 06:41 PM   #2
70c10guy
Re: 67-72 LS Swap motor mount options
I used dirty dingo sliders with those same perches! Worked out great! Actually put my manual bellhousing right where the stock bellhousing mounts were.
70c10guy is offline   Reply With Quote
Old 11-01-2016, 05:52 PM   #3
69gmcc10
69gmcc10's Avatar
I went with the 73+ saddles and dirty dingo mounts. These mounts and saddles set the engine at the correct height and allow you to move it fore or aft as you need to place it exactly where you want it i n the engine bay. If I wasn't greedy and didn't want it as far back as possible, I would not have had a single issue installing the engine but now I am trying to track down a high hump.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 11-02-2016, 04:30 PM   #4
knomadd
knomadd's Avatar
The 68 stands will work fine. You just need a small block motor mount like these and adapter plates to get it all mounted. Or, spend some more money and get the 73-87 stands, mounts and adapter plates. Either way, you'll be buying mounts and adapter plates.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
ls swap
