Old 10-27-2016, 10:31 AM   #1
Russ68gmc
Exclamation Best 4" lift for big block V6 GMC and pics?
I have a 68 GMC K20 and I'm looking for the best 4" lift kit for it. My engine weights 860lbs and I want leafs that will hold up to the weight. any suggestions on what kit to get I was looking at the rough country 4" heavy duty lift kit. also any pics of trucks with 4" lift that are k20?
Russ68gmc is offline   Reply With Quote
Old 10-27-2016, 10:44 AM   #2
fennderbender1
Re: Best 4" lift for big block V6 GMC and pics?
Hi, I have a 67 Chevy K-10. A few years ago, around 1996 I changed the 1/2 ton springs for 3/4 ton springs along with shocks. this gave me about 2" of lift. Now many years later I am rebuilding the truck again. It is a driver. The front springs have settled 1/2 inch over time. I carefully measured it out before pulling the engine. I intend to build 3" blocks to go between the rear axle and springs. 3 1/2 inch blocks for the front. Then I will figure out what length of shocks I need. The steering will be another issue to get set up as well. I think it will work. I will use new U-bolts too.
I will get you some detailed pictures as I get deeper into it.
fennderbender1 is offline   Reply With Quote
Old 10-27-2016, 09:17 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Just an fyi Blocks up front are a big no no. As for which kit, I'd stay away from the soft ride kits as they have softer springs. This is the delimma one faces when trying to keep a 3/4 ton when lifting. I'm gonna have my local spring shop build me a set of springs that will keep my K/20 3/4 ton. Sorry I can't speak for which over the counter kit will do what you need.
At the bottom of this article it explains Why front blocks are bad.
http://www.fourwheeler.com/how-to/12...-alternatives/
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 10-27-2016, 11:25 PM   #4
72 Copper C-10
72 Copper C-10's Avatar
I would give Off-road designs a call. I know they will have a solution for you. I will NEVER buy an off the self lift spring again. yes, you do spend a little more for the springs, but its absolutely worth it, if you don't want your truck to ride like a basketball... or a brick on steel wheels....
72 Copper C-10 is offline   Reply With Quote
Old 10-27-2016, 11:44 PM   #5
Russ68gmc
I'm not really that concerned with how it rides as much as the springs not sagging from the weighy of the engine. I live near St Louis and there is a place called stl spring I guess I will give them a call or some other places and just get custom Springs.
Old 10-27-2016, 11:53 PM   #6
57taskforce
All about them K’s
In my opinion your better off that way because they can build the springs to your application rather than the opposite.
Tyler
1968 k20 4x4, gmc, k20
