Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-31-2016, 03:12 PM   #1
tpimuncie
tpimuncie's Avatar
1960-1966 suburban carpet kit?
Hello I am helping my dad with a 1964 gmc suburban does anyone make a carpet kit for these or do you just need to get one custom made? thanks in advance also would a truck carpet kit fit in there and can add the carpet on flat parts thanks
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 10-31-2016, 03:26 PM   #2
bpmcgee
bpmcgee's Avatar
Re: 1960-1966 suburban carpet kit?
TPI,
I've never found precut carpet (or correct rubber) that was known to fit these suburbans. Apparently the floor isn't the same as a truck, although I've never had one to try out.
B
bpmcgee is offline   Reply With Quote
Old 11-01-2016, 11:36 AM   #3
tpimuncie
tpimuncie's Avatar
Originally Posted by bpmcgee View Post
TPI,
B
Thanks bro appreciate the reply
Old 11-01-2016, 01:30 PM   #4
65chevysub
65chevysub's Avatar
I had to take my 65 Suburban to an upholsterer and have the carpet made. Had the full floor, wheel-wells, lower gate and kick panels done in the 90's. Cost at that time was $500.
65chevysub is offline   Reply With Quote
Old 11-02-2016, 07:57 PM   #5
ogsRULE
ogsRULE's Avatar
There is a pretty easy solution for this. See Auto Custom Carpets: www.accmats.com buy a precut carpet for a pick-up for the front seat area and they sell material by the yard you can have made up for the flat back end. I did this and it was slick and cost effective. If there is a drawback it is that you are limited to loop carpet!
ogsRULE is offline   Reply With Quote
Old 11-03-2016, 12:02 PM   #6
VictoriaHardware
VictoriaHardware's Avatar
Originally Posted by ogsRULE View Post
See Auto Custom Carpets: www.accmats.com buy a precut carpet for a pick-up for the front seat area...
When you order, tell them what you are doing and that you want extra material left out at the back end. That will give you extra length straight back behind the front seats so you can get that flat floor covered in one piece. One extra yard will more than do it. Then order a second piece for the rest of the back floor.
I believe they can put any carpet they have in stock in the mold, so you can choose from all the colors.
VictoriaHardware is offline   Reply With Quote
Old 11-04-2016, 10:53 AM   #7
bpmcgee
bpmcgee's Avatar
ogs,
I was going to buy the front section of a truck and just leave the rubber mat in the back, but the place I was ordering from said that even the front section was different -- what was your experience? Does it fit well at the sides?
Brian
Old 11-27-2016, 01:54 PM   #8
tpimuncie
tpimuncie's Avatar
Thanks guys! Bougt a acc carpet kit for a truck and a additional yard and will workout just fine!!
Old 07-01-2021, 02:43 PM   #9
Merican68C10
Merican68C10's Avatar
I know this is an old thread however when I read it, I was left a little unsure and was hoping one of you 60-66 gurus could help me? I'm looking to get carpet for my Suburban.
Is the front floor pan section of a 1965 Suburban the same as a 1965 C-10 pickup truck or is the trans hump area different?
It appears that some guys say it isn't and others say it is and I'm just looking for some clarification. I understand that I will need extra yardage to do the second row seating floor section (I don't want carpet all the way in the rear cargo area, I'm leaving the wood floor uncovered) but I want to make sure the mold for the front floor pan is correct.
Also does anyone know if the C10 pickup rear cab wall carpet would cover the second row seating floor area by chance?
Any help is greatly appreciated. Thanks and have a Happy 4th all!
Merican68C10 is offline   Reply With Quote
Old 07-05-2021, 01:20 PM   #10
leadsledray
the hump area is the same. the difference is the passenger side between the seat and sill plate. the sub has a flat step, while the pickup is sloped. some suburbans may have had the floor/inner rocker replaced with the typical pickup piece. you can also screw or rivet in a simple filler plate.
leadsledray is offline   Reply With Quote
Old 07-06-2021, 01:22 PM   #11
Merican68C10
Thank you for the information, appreciate it very much!
