11-30-2016, 10:28 AM | #1 |
Need help with Block ID
Can some one identify the block that I have in my truck. The truck is a 1953 3600 but I think the block is not original to the truck. The color of the block is a orange/red. The number stamped just behind the dist is:
00097832 F55X There is also a number behind the starter: J224 I have looked on the common websites and can not id the block. I would like to know the following plus any other info that you might be able to provide from the ID#. Is this a 235 and if so is there any specifics about this engine? What year was it built and where? What color should a 1953 block be? |
11-30-2016, 12:21 PM | #2 |
Re: Need help with Block ID
It looks like a Flint manufactured '55 model year X code 235 from a 3100 series truck. According to this page a '53 235 truck engine should be blue-gray
http://chevy.oldcarmanualproject.com...esto/55063.htm Last edited by 1project2many; 11-30-2016 at 12:28 PM. |
11-30-2016, 01:08 PM | #3 |
THanks that help a lot. How did you determine that it was a 235 and is there anyway to know if this is a thrifmaster?
11-30-2016, 04:44 PM | #4 |
Most every specification for a 51 truck can be found here https://www.gmheritagecenter.com/doc...olet-Truck.pdf
The Thriftmaster designation went away in mid 49 when they went to the numbers on the hood side. 47/early 49 would be Thriftmaster while late 49---- would be 3100, 3600, 3800 or ---- https://en.wikipedia.org/wiki/Chevrolet_Advance_Design
