Old 12-04-2016, 01:37 AM   #1
Handfull 54
Handfull 54's Avatar
Remote Resivour leak?
I have a VW remote Resivour. One side (rear) is empty. Looking underneath. The hose from the empty is shiny all the way to the master cylinder. Resivour is located under the seat. Other side is full and hose is dry. Setup is 8 years old. Any suggestions. Thanks!
Handfull 54 is offline   Reply With Quote
Old 12-04-2016, 06:37 AM   #2
47 Fasttoys
47 Fasttoys's Avatar
Re: Remote Resivour leak?
A loose clamp at the reservoir? Maybe the incorrect type of hose and it took a while to bleed through?
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-04-2016, 11:31 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
It needs to be EPDM hose for brake fluid DOT 3, 4 and 5.1.
The VW reservoirs are a little thin and don't take much vibration to crack them.
dwcsr is offline   Reply With Quote
Old 12-04-2016, 01:30 PM   #4
Handfull 54
Thank you for the replies. I bought the Resivour and the hose at the VW dealer. It has been fine for a long time. I only have 3,000 miles on the truck but it has taken 5 years to do that. Mostly because of surgery that would not let me do anything. I'm leaning toward the Resivour being cracked. Will check it out Monday and let you all know. Thanks again for your thoughts. I appreciate it👍
