Old 12-04-2016, 09:19 PM   #1
Knixon804
Knixon804's Avatar
6.0 /4l65e swap. need help wiring VSS into 241
i have a 05 escalade drive train (6.0 lq9/4l65e) i am putting in my blazer with a 91 suburban np241. the harness i have made was from BP automotive and the connector is obviously incorrect. so do all i need to do is buy the 91 VSS plug and swap the pig tail? the wires on my harness are purple and green and the pigtail for the 91 burb is purple black. so im assuming match the purples up and the green to the black? thanks for help in advance
K5, 14B/60, 6" LIFT, 37" NITTO RIDGE GRAPPLERS, KMC BEADLOCKS, ORD CROSSOVER, 6.0 lq9/4l65e/241 in progress
Knixon804 is offline   Reply With Quote
Old 12-05-2016, 10:58 AM   #2
throttle out
Re: 6.0 /4l65e swap. need help wiring VSS into 241
I made my pigtail to do what your trying to do. The plug at the T-case I got from Autozone, they called it a headlight plug and it had 6" of flying leads on it. The other plug you shoul be able to find in that same section of the store as well. I had a 01 silverado light harness laying around and one of those plugs fit the LS harness VSS plug perfect. Solder them together, use adheasive shrink tubing, and be sure to use a good cable protector or sheathing. The wires for the VSS are not polarized and can be wired either way.
This is the plug that will fit the VSS connector on the T-case
http://www.autozone.com/electrical-a...?checkfit=true
I believe this is the one to fit the plug on the LS harness
Good luck!!
Sammy
throttle out is offline   Reply With Quote
Old 12-06-2016, 11:15 PM   #3
Knixon804
Knixon804's Avatar
Perfect! Thanks for the info
Old 12-08-2016, 11:25 AM   #4
JMac11
JMac11's Avatar
THe light plug will plug into the LS Vss harness?
JMac11 is offline   Reply With Quote
Old 12-10-2016, 09:00 AM   #5
Knixon804
Knixon804's Avatar
yep. i ordered the part and it plugs right in!
