Old 12-07-2016, 07:38 PM   #1
KyleSeal
KyleSeal's Avatar
Pulley Problems - Do I have all the right stuff?
Building a '70s 350 for my '70 Chevy, and I have the correct alternator bracket and power steering pump I believe, and a long water neck. But nothing lines up! I have a new pulley on the PS pump but it seems to be very close if not exact to the original (original was bent). Is the crank pulley correct?
Photos attached.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 12-08-2016, 12:48 AM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: Pulley Problems - Do I have all the right stuff?
Original '70 would have came with a short water pump. Which also means different alignment for the PS pulley. If you keep the long water pump, then you need a PS pump and pulley for a long water pump setup.
Is the crank pulley for short or long water pump?
If it's for short water pump, then you will also need to change your water pump. Or get the correct crank pulleys for a long setup. The original crank pulleys for a short water pump would be stacked, meaning the PS crank pulley is a separate bolt-on pulley that stacks on to the crank pulley. If I recall correctly.
You aren't the first nor the last to get mixed up with this. There are probably 100 different pulley setups for the SBC spanning decades.
Sometimes it's easier to pull a complete accessory setup off something in a junkyard and replace/rebuild the parts for that year vehicle.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 12-08-2016, 12:56 AM   #3
Captainfab
60-66 Nut
No you do not. You have a long water pump and the water pump pulley looks like a long pump pulley. Then you have short water pump pulleys on the crank. The power steering pump and bracket are for a short water pump. However it looks like the PS pump pulley does not line up with the correct groove on the crank.
As storm9c1 said, your '70 originally came with a short water pump, as did all trucks from '55-'72 with both small blocks and big blocks.
Old 12-08-2016, 01:18 AM   #4
crazy longhorn
Fabricate till you "puke"
The steer pump/brackets, look right for your 70.....I agree with Capt fab, the water pump is 73-up, as is the top pulley. Understand, that any sb Chev, is the same distance, from the front of the balancer, but ALL of the pullies/parts need to come off the same engine Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-08-2016, 08:58 AM   #5
PGSigns
PGSigns's Avatar
Kyle when I did my 66 I went to a long pump and used everything form a 75 truck. A trip to the junk yard to get it all off one car or truck will get you what you need.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
1970, 350, brackets, chevrolet, pulley
