12-09-2016, 01:51 PM | #1 |
Door striker plastic bushings, what are you using?
The aftermarket ones I'm seeing are a lot thicker than factory and don't fit over the pin.
I would call these not very good |
12-09-2016, 02:13 PM | #2 |
Cruzzzn' Vet
Re: Door striker plastic bushings, what are you using?
Picked up some new ones at AutoZone, had only 2 bushings and they were white.
12-09-2016, 03:12 PM | #3 |
I replaced the whole set, they were pretty beat up. I got the actual GM part, so there was no issue with size.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
12-09-2016, 04:05 PM | #4 |
Piece of 1/2 Pex tubing on mine. Works perfect.
12-09-2016, 05:45 PM | #5 |
Post Whore
I bought new ones from lmc..they are white and work great..later on I read where a lot of people use the above mentioned pex..
12-09-2016, 06:09 PM | #6 |
Pex
Desert |
12-09-2016, 09:04 PM | #7 |
Do you have the part number by chance?
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
12-09-2016, 09:31 PM | #8 |
I machined my own out of UHMWPE.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
12-09-2016, 09:52 PM | #9 |
09601750 ; 09815751 Not sure if they are available any more, but you can get some at this place. I just don't know if these are actual GM parts. http://www.truckandcarshop.com/trucks73_91/t73_018.html
12-09-2016, 10:01 PM | #10 |
I believe this is where I got mine, but they changed their web-site, and I'm not sure how you order from them. Maybe call them?
http://www.auveco.com/OnlineCatalog/...html#?page=502
01-17-2017, 12:03 PM | #11 |
Finally found were you can get these. And these are Direct GM Parts:
http://www.clipsandfasteners.com/sea...?Search=a20562
01-17-2017, 12:49 PM | #12 | |
01-17-2017, 12:51 PM | #13 |
Those are for Fords and they are .050" thicker than the Chevy ones that measure in at .700". I tried them and they didn't work to well. They caused the door to hang up on the opening.
01-17-2017, 02:38 PM | #14 |
01-17-2017, 07:05 PM | #15 |
I replaced my 74 with a set from Oreilly's. Bolts, washers and bushings. No problems.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
01-17-2017, 07:12 PM | #16 |
1/2 inch pex. Holds up a lot longer than the crappy help aisle bushings.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
01-17-2017, 08:03 PM | #17 |
Problem I have with PEX is that I can't find anything less than 25ft in length....
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
01-17-2017, 08:05 PM | #18 |
Stop and talk to a plumber. He'll probably give you a scrap out of the back of his truck.
Mike
01-17-2017, 10:55 PM | #19 |
Pex. a few bucks will get you enough to do a ton of them. Home depot had like a 4 or 6 foot piece i think?
On mine -- i had to make a slit the length of the tube to get it to slide over the striker. the next size up was too big. works great, dirt cheap. |
01-18-2017, 08:03 PM | #20 | |
01-18-2017, 08:59 PM | #21 |
I got 4 ft of pex at Lowes.
01-18-2017, 10:04 PM | #22 |
What I did was order other stuff to make it worth the shipping. Like a set of door pins & bushings and a few other small items.
01-18-2017, 10:29 PM | #23 |
01-19-2017, 04:13 AM | #24 |
Like mine, it looked like it had been run thru a chipper shredder, and survived somewhat.
01-19-2017, 10:41 AM | #25 |
I find great OEM strikers from Suburban back doors that have little use. Also, I use my pex expando tool to slide the pex over the striker bolt.
