Old 12-16-2016, 12:52 PM   #1
pete57
wiring for Boyd efi tank
Didnt know if i needed to post here or the electrical section since its for an LS swap. Boyd efi tank with aeromotive in tank pump, do i run both hot and ground back to the cab or just hot and run my pump ground to the frame with the sending unit ground? First time doing fuel injection. Thanks..
pete57 is offline   Reply With Quote
Old 12-16-2016, 02:45 PM   #2
dayj1
Re: wiring for Boyd efi tank
Grounding both the sender and the pump at the frame will work just fine.
dayj1 is offline   Reply With Quote
Old 12-17-2016, 04:20 PM   #3
pete57
Thanks.
