Old 12-21-2016, 01:04 AM   #1
suburban99
suburban99's Avatar
What belt to use for a 6.0 LQ4 without AC compressor?
Swapping a 2002 6.0 LQ4 into my 1972 K10. What belt number will work without the AC compressor? Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 12-21-2016, 02:53 AM   #2
izzy_Britton
izzy_Britton's Avatar
Re: What belt to use for a 6.0 LQ4 without AC compressor?
I am kinda scratching my head that this question...
The AC compressor runs on its own belt. the rest of the FEAD (front engine accessory drive) belt doesnt depend on whether or not there is an AC compressor on the engine at all.
which ever belt you have is all the belt you need. typically the only other question you might have to ask is which alternator you have installed as they do tend to have different size pulley from the standard to the high output.
105 AMP ALT requires the 92.9 inch belt
145 AMP ALT requires the 93.585 inch belt
AC only belt is 38.453 inches
hope that helps to clarify things a bit?
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
